Marmalade 2.1
Stephanhipwell
Post by Stephanhipwell »
yeah sure, i'll warn you tho it ain't pretty. i just did the mod quickly for now so i could get it running,i'll take some piks in the morn.
i think a header like the one i'm going to make would be best op TBH. i'm makin mine out of stainless, if you like the look of it i could do one for you?
AMBROSIA
Post by AMBROSIA »
Cheers :wink:
Stephanhipwell
AMBROSIA wrote:I spoke to Jim about conrod bolts and he said he reuses them for all his rebuilds without any problems. That's ok for a stock engine, I guess :roll:
I was tempted to get a set of 2.2 pistons and liners off him until I saw the price :shock:
Have a chat with him, he knows his stuff.
seem to be havin probs with the site :(
AMBROSIA
Post by AMBROSIA »
http://www.theengineshop.info/
You can only order using internet explorer, firefox does not work.
Oh, I've just finished the exhaust conversion, sounds wikkid.
Stephanhipwell
ah i see now. thanks :wink:
Stephanhipwell
now that christmas is done, i am starting again on the engine.
couple of questions tho,
i have some bent pushrods, any info on best place to get new ones?
and anybody know to what i should torque the new non stretch rod bolts?
thanks
AMBROSIA
Post by AMBROSIA »
I got a replacement from jim @ TES for £3 secondhand.
How did they get bent?
Stephanhipwell
they were like that when i opened it! honest! :lol: no idea mate, guess previous owner revved it a fair bit or summat.
i asked in TES but i think he said he did not have any or somethin. :?
AMBROSIA
Post by AMBROSIA »
The reason I ask is that I had one on mine from the old 1.9 'camshaft failure'.
I had one bent presumably after the valve wacked the piston.
I have a couple spare from someone else's engine.
Let me check that he's cool and i'll send them too you.
Iain.
Stephanhipwell
:D
tencentlife
Post by tencentlife »
All the cases of bent pushrods I'm aware of on the wbx have been due to intake valve seizure; for some reason, they like to stick sometimes on high-mileage engines. Probably due to insufficient detergency of the oil, over a long time. But anyway, the valvestem seizes in the guide, and the pushrod is what gives.
Stephanhipwell
cool, i'll have a look,
i got a gasket set from TES, it came with some sealants, dirko-s and a unmarked white tube, am i right in thinkin the dirko is for the bug rubber gasket and the other is for the barrels?
thanks again for the info guys. :wink:
AMBROSIA
Post by AMBROSIA »
The dirko is for the heads/ barrels, the white tube is for the case halfs (yellow sealant).
Note on the sealant use:
I put a very small bead around the liner bases pior to fitting the black o ring.
I leave the green one dry.
You only need a thin bead around the cylinder head and be careful not to get it too close to any water holes.
I have a couple of spare pushrods you can have.
Let me know your postal address and i'll post them.
Iain.
iain.ambrose@btinternet.com
Stephanhipwell
AMBROSIA wrote:The dirko is for the heads/ barrels, the white tube is for the case halfs (yellow sealant).
Iain.
just received the post, thanks mate, i owe you :D
Stephanhipwell
here's the next question...
i can't seem to find how much i should torque the con rod bolts to, i'm guessing that it would be differnt to stock bolts as they are non stretch. anybody know what the torquing should be?
