Drove the buggy about ten miles Saturday and it would run really nice at light or no load. As soon as I tried to rev it and load it up it would fall on it's face.
In second gear if I brought it up easy to 2500 rpm and then pushed it I could get 3 lbs. boost to show on my temporary vac/pressure gauge.
It would start to falter so I had to let up.
I went home and installed an idle jet up one size and all that did was make it run too rich at idle and low end. No change on the miss under load.
I had to call it a day then.
Pulled the carb yesterday and installed a 135 main jet and reset the accelerator pump shot to as big a shot as it can give.
Had a rain day today so I did a few more little things to the buggy.
I hooked up a fuel pressure gauge so now I have three gauges to watch over as I tune the engine.
Fuel pressure
Vacuum/boost hooked to blow off valve.
Boost off the turbo waste gate fitting.
Had more time than money so I dug up a scrap of 2 1/2 inch exhaust pipe and built me a exhaust bend off the turbo.
I needed to make a tight 90 degree turn right off the turbo so I cut three 15 degree double angles off of the end of the exhaust pipe and welded them all together.
I forgot to take any pics of the cut pieces and only remembered after I had it all welded and ground to a finished piece.
Hung it up and shot a coat of BBQ paint on it.
Installed it and stood back and admired my handy work. It isn't as nice as a radius bend but it would have cost me $20.00 plus shipping to get one to me not including the wait.
Fired it up to see what it sounded like.
http://s144.photobucket.com/albums/r173 ... I_2695.mp4
There sure is a lot of moisture in the exhaust system when it rains all day!!
I am out the door to test it right now.. the clouds have moved away for the time being.
Clonebug
