No, the Audi insert does NOT just fit in and bolt up. To use the Audi inserts without Ray's rod extension, the following modifications are required: 1) spring plate modified for the Mazda bearing, 2) bottom insert spacer, 3) radial top insert spacer, and 4) spring plate-to-strut bearing spacer. All of these are custom parts requiring fabrication. #2 & #3 are needed with Ray's rod extension also. Without #1 & #4, the Audi rod end (smaller diameter portion with thread) is too short. With #1 and with a too short a version of #4, the Audi rod end fits, but spring plate rubs on the strut bearing mount when a sudden big bump is hit (my car does this now as I don't have the proper #4 installed). When I get #4 made, I'll show you.sharkskinman wrote:(bill)
so your saying with the e30 springs ..the audi cartridges just fit in and bolt up
as they are same length?
I haven't used the standard E30 spring with the Audi insert, but I think the spring is too long. The strut assembly would probably have no droop travel because the Audi insert without a rod extension would compress the standard E30 spring beyond the load applied by the car.
The standard E30 spring works with the 411/412 insert (see my thread), but insert replacement is limited to NOS availability.
The E30 M3 spring is shorter and works great with the Audi insert without rod extension (using mods #1-4). Insert replacement is not limited to NOS availability.
The E30 M3 spring also works with a 411/412 insert without needing to do #1-4 above (see Wally's thread), but insert replacement is limited to NOS availability.
