Interesting... If I had the money, I wouldn't mind a pro chassis like yours.
Few questions/comments...
What kind of r&p is that? It not an end load, not a center load. Is that custom for the arms or do they sell mid-load racks and the arms built around that?
Are "you" planning on adding any diagonal bracing to the floor or are you relying on the flooring itself to brace that?
Also, the cross brace on the rear trailing arm (from pivot to pivot) I like it, is that a permanent piece or just there for mockup?
I like those double sheer upper front shock mounts, too. Very cleN install.
Keep the photos comming.
The rack is an "off the shelf" Saco rack... so... Yes...
The floor will remain as is save for some seat mount tubes... but I do not intend to add any more bracing. As for the rear arms, they will stay as they look. (With the plating on the side fully welded of course.
I've just received some packages from Del-City and Waytek.
Hey Desert-Guy, where'd that one red wire go again?
