It's Back, It's back, after almost 50 years the Tow'd is ...
Re: It's Back, It's back, after almost 50 years the Tow'd is
When in a seated position does the raised fenders height cause any visual problems? If you get an inspector or an "on the road" officer that is having a bad day or for some reason is being an "BEEP" then visual blockage can be a problem. I am interested enough in this right now to be thinking more and more about it.
Also, after seeing your latest post on your Tow'd build, I still have to figure away around the installation of turning brakes assuming that they are still a problem on the street (here).
Iguana
The two'd retains the donor VW VIN Number on the rear section of the torsion housing if that helps.
Buy a Kit, Build a Dream
Hmmmm! That means that aftermarket torsion housing could be a problem
Not if you keep that critical section of a VW pans tunnel...Hmmmm! That means that aftermarket torsion housing could be a problem
- Big Bus
Ol'fogasaurus wrote:When in a seated position does the raised fenders height cause any visual problems? If you get an inspector or an "on the road" officer that is having a bad day or for some reason is being an "BEEP" then visual blockage can be a problem. I am interested enough in this right now to be thinking more and more about it.
Lee , the tops of the front fenders are still lower than the bottom of the windscreen , so the inspector would have a hard time saying that they obstruct your vision .
As for the turning brakes , yes they are not legal here either , but what they can't see won't hurt them , either making the handles removable while on the street or fitting a handy padded arm rest over the levers to hide them
Andrew
- dustymojave
Those fenders are no where near as high as the ones on my SUV, or either of my pickup trucks. And for blocked view...There is hardly any car approved for the roads in any country which offers as clear of a view to the front as a Tow'd, even modified as Big Bus has his. You'd have to drive an Isetta with an all Lexan door to have a more clear view.
Iguana said "The two'd retains the donor VW VIN Number on the rear section of the torsion housing if that helps."
Ummmmmmmmm....maybe sometimes...
In California, according to JimMcGinty, Chief of Police for the City of El Centro, who owns and drives a particularly nice Crumco Baja Bug (see Hot VWs mag) on the streets of his fair (and hotter than hell!) city, at least 18" of the tunnel including the VIN is required to be retained. If one builds the car using a fabricated torsion and yokes, that gets complicated for registration.
I would recommend for street registered use, building the car using an original registered pan torsion housing with tunnel section not severed. Typical Tow'd construction is done with the tunnel cut off just ahead of the torsion tube, just as it is with tube frame rails built with a VW torsion housing. I've only ever seen 1 Tow'd with the tunnel extending forward of the torsion tube far enough to include the VIN, but not the 18" as in McGinty had Rick Crum build his BAja for him. That Tow'd had the lower tunnel extended forward as a gusset to a lower center rail to the beam mount and lower side rails as shown in mkparker's above. Mk's Tow'd, BTW, is the coolest one I've ever seen.
Lake LA, Mojave Desert, SoCal
Retired Fabricator
Retired Fabricator
Thanks Dustymojave the 18" is interesting to know. I agree with the assessment of blockage of the front but they don't usually have to be inspected by harassed local inspectors either. When down in OR to check on some inspection things it was interesting to listen to the Sherriff talk and some of the Deputies talk away from the boss (nothing was said bad about the "Boss" I assure you). The same could be said when getting a ticket from the Sherriff... "doing my job right or wrong".
Inspectors come in all sizes and shapes if you know what I mean. the same with titling of cars/rails. The "complicated" bit about an aftermarket torsion housing is just what I was talking about.
I do agree with you that to license for the street whether you use it that way or not.
Still thinking about it unless a Berry Mini T C-cab comes up for sale
- chuckput
I fixed it for you!dustymojave wrote: In California, according to JimMcGinty, formerChief of Police for the City of El Centro, who owns and drives a particularly nice Crumco Baja Bug (see Hot VWs mag) on the streets of his fair (and hotter than hell!) city, at least 18" of the tunnel including the VIN is required to be retained. If one builds the car using a fabricated torsion and yokes, that gets complicated for registration.
McGinty only drove his Baja on the streets of my fair city on special occasions.
Iguana
So does that mean you are now the chief of Police ?chuckput wrote:I fixed it for you!dustymojave wrote: In California, according to JimMcGinty, formerChief of Police for the City of El Centro, who owns and drives a particularly nice Crumco Baja Bug (see Hot VWs mag) on the streets of his fair (and hotter than hell!) city, at least 18" of the tunnel including the VIN is required to be retained. If one builds the car using a fabricated torsion and yokes, that gets complicated for registration.![]()
- chuckput
I wish (not)!!Iguana wrote:So does that mean you are now the chief of Police ?
Mc Ginty left and I am still here enjoying the weather!
Can you buy just the plans while you save for the body?
Any idea around what the frame hoop is going to cost? CrMo?
Considering top/bottom rails (w/triangulated bracing etc) and about a foot of vertical spacing between them up front for A-arm mounting etc.
That would probably be a nice score for a local, but I'll be able to get a Texas title for the real thing.
(even with a kit)
With that mystery version, dubious.
The molded in fenders are kinda nice.
(even with a kit)
