I'm finally at it again but somewhat revised.
Over the last few years I have changed my mind many times, still have all the parts I mentioned earlier laying around, but something didn't feel right and I've gone a different rute.
The motor is for my Porsche 912 that currently have a very tired, leaking VW 1600 DP in it. This particular engine was one I had laying around on the floor in one of my garages for years with no protection and maybe even seeing some rain once when a wall was blown over by a storm.
I installed the thing a fired it up a few years back and have driven it very little in the past years, last year when installing a set of 40 IDF's I found a small bolt down one intake runner, fished it out and kept driving
As stupid as I am I have started building the turbo setup on this old engine. Have already driven it, on boost with no gauge, stock fuel pump without boost reference, didn't bother to clean the intake pipes for alu dust and hopefully that's the reason it began to drive really rough. Hahaha I didn't even bother to put clamps on the silicone intake couplers (Cheap boost limiter!)
I do know the right way to do things, I really do! But sometimes, well I don't know why I don't.
Maybe it becomes some sort of challenge in my head, that I have to drive the damn thing filled with shavings in the intake just to see if it makes it. What can I say, already said it. Stupid....
A few months back I bought a tig welder for my projects and got started again. The plan was draw through like before but on the stock size engine.
I had recently somewhat restored my old Audi A6 1.8T and that gave me the idea to use the K03 turbo on the Porsche/VW.
The new plan is to build the thing, a working mock up and then pull the engine and rebuild it the right way.
After finishing the exhaust manifold I started wondering about intake manifold for the DCOE. But one thing bothered me! What if, due to the leaking valve, I had a spit back and all that premixed gas in the manifold went bang and lit the car on fire? The plan changed once again..... Blow Through.
The new plan is as follows:
Stock building width, first std 1600, then latter a 92 thick wall set with the MOFOCO heads I got.
SCAT ratio rockers which looks way better than the CB kit I did install on this junk engine. (But i forgot the ratio, think it's 1.25:1)
Oh I also bought a very nice SCAT stroker crank but would much rather have a stock 69mm CW welded original in it. I can't explain it and I even tried to sell myself the idea to use the SCAT one I did buy for this build. Somethings are not right upstairs
Weber 40 IDF on type 3 manifolds with CB hats on and their turbo emulsion tubes and modulator rings. The current jets are main 112 and air 200, can't remember idle but I have a few jets lying around when I start to tune it.
K03 stock Audi turbo. I bought a China one to start on and a used original for rebuilding.
Old style doghouse fan house I had to install to get room for the Webers, haven't had time to redo the thermostat and flapper system yet but will do so when it gets pulled out again.
Intake tubing is 2" and exhaust is 2.5" straight out from turbo. The future plan is to make a Helmholtz resonator to take away the lowest pitched noise.
Well I could go on and on forever but this is probably already way over the top.....
The next days I will add some pictures of the progress and hopefully give some inspiration to you guys and then I have a few questions.
Question 1, that I halfway found the answer to in the type 1 section: Does air get sucked/pushed in through the grill/vents in the hood or is there a vacuum above the grill? I kind of already knew the answer because stock the engine bay is closed from the underside of the car so air have to come in from the top.
But I would think the overside of the hood would be in vacuum since the air has a much longer route over the car than under and therefore acting like a wing. Any thoughts on this? Does air actually get's pushed in or is the vents just holes for the fan and carb to suck through.
I think it's kind of important to the way I plan to construct a visor to divert air to where I want it to in the engine bay.
I actually just deleted the second question, In the hope that you guys would like to dig a little deeper into the first one.....
Regards
Lars
