Turbo Engine, Tranaxle, and other questions...
- petew
Re: Turbo Engine, Tranaxle, and other questions...
You better show us the tool you use for balancing the deep sump...
,,, and use a counterweighted crank, even a stocker with welded on counterweights.petew wrote:So what you're saying is, "get it balanced".
(DPR and DMS make them that exactly way and they have been winning races for 40 years)
A stock T1 crank with no counterweights is ~guaranteed damage between ~5600 and ~6200 RPM.
It won't die instantly of course, pounding out the center mains in the case takes time, but engines do not self heal.
Balancing a stock crank probably helps reduce the severity, but, done even perfectly does not fix the problem.
Its a design issue, it simply wasn't designed for high RPM, nor tested. It flexes in the middle.
A truly bone stock T1 engine probably couldn't hit 5600 RPM at WOT in neutral by design.
(carb was too small, valve float etc)
madmike
DPR or Demello's are all I will use. or a $cat forged
madmike
"Pounding out the center Mains"
Stock Crank with Clueless driver
- rubenski
Ouch...
Verstuurd vanaf mijn SM-A528B met Tapatalk
That poor thing suffered a slow, painful death by idiot.
Did it ever stop or did they finally shut it down because they could hear it over the radio?
madmike
No, I think they just turned up the radio by the looks of it
These came out of a old Dune buggy
