What compression ratio should I be running on a turbo bug
- buguy
Re: What compression ratio should I be running on a turbo bug
And damn. A gm intake sensor is only $20! I could hook one of those in and connect it to my Fluke for next to nothing. Doesn't seem like something that you would really need to monitor all the time.
Clonebug
The intake is cold before the turbo because you have frost on your intake. The intake temps after the turbo are what you are concerned about.
Your after turbo IAT's will depend on the ambient intake temps which in your case are lowered by the fuel and venturi effect and how much boost you will run.
10 psi will double your intake temps if the air going in is at 80 degrees. After turbo temps will be 165 degrees.
With the cooling effect of the fuel your ambient temps will be a lot lower I would guess.
You could possibly put your Fluke temp sensor against the intake after the Tee but I doubt it will react fast enough to get an accurate reading.
- buguy
I guess I've never heard of anyone reading the IAT on a drawthrough. I've seen some using WI but they must have just been guessing at how much to spray.
- petew
- buguy
Maybe I could just run a separate fuel pump and pump water into my secondarys on the carb. Make it like a 2 barrel with built in W/I!!!!
66brm
- buguy
By the looks of my tank I must have tried that a long time ago!
