Had some time after work now that it's not pitch black when I get home to check weights on reciprocating parts.
Pins are all dead on.
Pistons are within 2grams of each other. (Will wait until I have rings and check with a pin and rings before removing anything)
Rods however are going to need some work...
I pulled some out of my little box of rebuild rods I picked up from the local VW guy when he closed down. It looks like some 1.8s and some 1.7s based on the small end pad height. (don't know which is which just that they're different.)
So I grabbed four that are the same style but the weights are as follows; 760g, 764g, 785g, and 786g. You can see in the photo most of that weight is where the angle is ground into the cap, it takes part of the 021 number on the right set but on the left it's not even close to touching.
My question then is: Can I balance them in pairs and run them opposite each other? Eg. 2x @ 785g running opposed to each other and 2x @ 760g opposed to each other. This would in theory balance the reciprocating weight and so long as end to end balance isn't far off should be okay I think. Let me know if I'm crazy for even thinking of trying that.
