2084 Turbo Build
kangaboy
Re: 2084 Turbo Build
Post by kangaboy »
V8Nate wrote: Sat Mar 13, 2021 6:15 am Mine says with 1.5 rockers
That's and 86a card.
Here's the link for the b.
http://webcamshafts.com/pages_vehicles/ ... 01095.html
'74 Standard- 2084T, MS3X3
'76 Westy- Stock 2.0L L-Jet
My Megasquirt Turbo Build
2084 Turbo Build
V8Nate
Post by V8Nate »
That it is, I wonder why it doesn't specify
Clonebug
Post by Clonebug »
I took my info off aircooled.net. It states .575 lift with 1.5 rockers. .575/1.5= .383"
https://vwparts.aircooled.net/Web-Cam-T ... 00-102.htm
kangaboy
Post by kangaboy »
Alright, little update. I placed my CB order yesterday with the following:
1.4 forged rockers
dual taper chromoly pushrods
28mm lightweight lifters (cam is a EP1 blank)
pushrod tubes and seals
straight cut cam gears
650 dual springs (just need to get something in hand so I can test and get some numbers, even if these don't work)
I believe I will have everything to bolt the long block together with the most recent order. Haven't heard from WebCam after placing my order, so I suspect they are experiencing the typical Covid delays.
2084 Turbo Build
madmike
Post by madmike »
I've been running them 650's ,, should work for ya :wink:
kangaboy
Post by kangaboy »
Awesome Mike, thanks for the reassurance. The springs are really the last part of the whole build that I can't wrap my head around.
Figured I would NA the motor for a small break in period with just the outer springs, and then put the inside ones in when I hooked up the boost.
2084 Turbo Build
madmike
Post by madmike »
I hear ya :lol:
buguy
Post by buguy »
Can you do that? I would think if it's cut for dual springs you would have to run them. Don't know that for sure though.
madmike
Post by madmike »
It's done all the time Mike, Mostly just for Cam & Lifter breakin :wink:
buguy
Post by buguy »
I wasn't sure if the spring would walk since there is nothing to ride on in the inside of the spring.
kangaboy
Post by kangaboy »
buguy wrote: Fri Apr 09, 2021 1:55 pm Can you do that?
Yeah, I have heard of several others doing it, so I figured it was acceptable. I didnt think of it myself by any means. I'll let you know what happens when I get there.
2084 Turbo Build
kangaboy
Post by kangaboy »
Well, my cam came in, and I immediately noticed it wasn't what I ordered :(
I wanted it to be on an EP12 blank and was going to run the CB Ultralight Weight Lifters (already in the mail) because I know they are compatible. I called WebCam when I made the order, so I have no invoice besides the one they sent in the mail with the cam itself. I'm hoping they take it back and send me the correct one, but having made the order over the phone, I'm skeptical.
2084 Turbo Build
kangaboy
Post by kangaboy »
Apparently this has been an issue for them lately. Rep I spoke with mentioned they don't even have any EP-12 blanks right now, but they'll send me one when they get it in...could be over a month before they get blanks in :(
2084 Turbo Build
kangaboy
Post by kangaboy »
Pic of the cam card before I get it all packed up for return.
2084 Turbo Build
buguy
Post by buguy »
Are you getting the same cam with the correct blank?
