Fitting 4W disc brakes? Other wheels?
Yep...we are actually pretty much on the same page. I did catch that you are using an assymetrical strokelength . In reality...that is the big thing I think all type 4's need...stock or modified...is a larger volume master cylinder all around. I have been playing with installing a late bus master cylinder. The 21mm one. Either longer stroke on a 19mm or longerstroke and larger piston diameter would do well even with stock. The stock 19mm was just adequate. Ray
- Wally
- func412
Thanks for good information of your beetle setup!Wally wrote:
Finding a strong big-ish rear caliper with the handbrake lever embedded in it does not seem easy tho (I looked through 634 ebay listings of calipers yesterday...)
Unless s/body shows me the 944 part that Bill pictured fitted to the rear of a 412![]()
I´m not sure if this helps you, but I´ve planned some of these calipers at the rear. They all have handbrake lever embedded and are used originally at the front... Here are the biggest nominees for the 412 rear disc brake calipers...
Citroen BX front calipers (50 mm cylinder) ->
Saab 900 front brakes until 1987 (double 54 mm cylinder, for vented rotors in turbo only)->
Subaru Leone front calipers (54 mm cylinder)->
Those are the girling and or Teves Audi 5000 rear calipers I used originally.
Actually...its been a while since I measured the stroke on the master cylinder. I thought it was closer to 30mm. I do know that the front and rear piston positions have identical stroke and volume on teh stock 19mm master cylinder. Ray
- ubercrap
Hmmm, is there any way to use a 90 degree fitting of some sort at the caliper where the lines attach and/or maybe notch the caliper mounting flange for clearance (possibly not a good idea)? Oh, well, I need to see when I get the calipers what exactly the clearance problems are...func412 wrote: Thats good idea. I must say I tried that too, but unfortunately the brake fluid lines are located between the caliper bolt section. If you move the calipers other side of the mounting flange, there is not enough space to attatch the brake lines.
- Wally
- Ephry73
- func412
Thats true.Wally wrote:50mm or more is way too much for the rear unless you use big 4-pot calipers at front...
I was thinking that 4x38mm calipers with BMW 302mm discs at the front would make good brake balance when using 1x54mm calipers with MB 262 mm discs at the rear? Let´s see what happens.
Moi moi!Ephry73 wrote:Moi moi Func! I like the idea of using those calipers in the front. Now, the CB rear brakes may not be a bad ida, but I believe there is a guy in Sweden who was using rear Volvo calipers off an 850 I think. I will have to dig the magazine up.
CB brakes... Volvo 850 calipers. Tell me more about those setups! Thanks!
- func412
I´ve heard that Porsche 944 front calipers has also the same bolt pattern than late type 3 and all 411/412 (76 mm). Anyone tried that?
Here are two pictures from one Finnish guy's web pages of fitting 944 brakes to type 3 spindle.
There is also one way to make rear disc brake conversion, which doesn't increase the wheel gauge -> http://koti.mbnet.fi/ywa/jappe/tekniikk ... jarrut.htm
I´ll mention this BMW caliper swap here too FYI http://www.pelicanparts.com/techarticle ... lipers.htm
- Wally
