why build a T5 and not A T4
"T5" USES T1 heads...
If you have a wasser motor, and are thinking "turbo" I suggest you might just think about keeping it water cooled, particularly if it is indended to be a driver.
The ability to have REAL HEAT practically for free is a nice bonus.
The wasser heads flow well, (or can be made to do so) and they tend to stay on under boost. They just need real work if you are revving >7500 or wild lifts.
Even a 1.9 is a "factory 1914", put some H-beams in an otherwise stock setup, and blow.
Perhaps some ARP head studs..
Even all stock internals have held up to some rediculous boost.
I know the radiator is a PITA...
pocketrocket
Vtec this:: Mike, The vanagon block is a die cast not sand cast as with the new brazil cases. It comes with a 1.5 sump built right in. It has a full flow feature oil system. Now the bad part it is not cheap to re-machine the block & do it right. Use a 94mm P&c kit with a 86 stroke. That way you can use bug type heads. With the 101.6 P&Cs you would have to use a head like the AutoCraft 910s. Rocky
- vtec this
I saw some of those 910's on the samba for $5,000!!! that is pretty wild. i think i will stick with the stock setup minus the watercooling. I would like the max stroke out of it since i am limited to 94mm pistons. i think there is someone in the Netherlands with a 90mm full circle crank in one? I guess i should not speak like that. my budget will determine what goes into this engine. in that case, more realistically speaking, i can get the jackets cut, and runn 94's on what ever crank that is in there. So is it $900-1300 to cut the jackets and put in the spacer for type 1 cylinders at Rocky Jennings?
thanks-mike
thanks-mike
Max keltvik
pocketrocket
Max keltvik
pocketrocket
Max keltvik
pocketrocket
Max keltvik
pocketrocket
pocketrocket
