What is your ride height set at currently front and rear?
Shane
Adjustable Sway Bar Setup, Corner Balancing,Alignment Advice
Pooter
Bill K. wrote:Here's an update after putting on the SAW adjustable spring plates and getting cross-weight balanced with full tank and 200 lb of driver.
..............LF/RF
Wgt, lb 435/413
Wgt, % 20.2/19.2
Hgt 3"/3-1/16"
...............LR/RR
Wgt, lb 681/623
Wgt, % 31.6/29.0
Hgt 5-1/2"/5-3/4"
Total Wgt, lb 2152
Cross-weights:
LF-RR Wgt, % 49.2
LR-RF Wgt, % 50.8 (aka wedge)
Side-weights:
Left Wgt, % 51.8
Right Wgt, % 48.2
Rear-weights:
Front Wgt, % 39.4
Rear Wgt, % 60.6
The rear is set at 1 deg toe-in and -2 deg camber.
The front is messed up on the left. Can only get 0 to positive camber. New brazilian beam with bent C-arms? Anything I should check?
Right is maxed out with extra eccentric adjusters at -1.2 deg camber.
Closer![]()
Bill
Bill,
Where did you go to get the car corner weighted/balanced, and aproximately how much did it cost?
thanks,
Nick
