type 4 turbo 2.0L
- turbobaja
Re: type 4 turbo 2.0L
WOW! That's a tight fit in there! Looking really good though. Lots of progress, must feel good. Is there going to be a cover over that filter element? Looks like it's gonna breath in the hot air from the shroud down there, but probably won't be a big deal with E85
. Gonna be slick with the deck lid shut, what a sleeper!
DON'T QUIT
DON'T QUIT
- sweetlokin66
It does doesn't it
- sweetlokin66
turbobaja wrote:WOW! That's a tight fit in there! Looking really good though. Lots of progress, must feel good. Is there going to be a cover over that filter element? Looks like it's gonna breath in the hot air from the shroud down there, but probably won't be a big deal with E85. Gonna be slick with the deck lid shut, what a sleeper!
Yes it does feel nice. I needed a brake from the body work
If I need to do a head retorquing or something of the sort all I need to do is pop off the intake, shroud, and aluminum tin and there is tons of access with no need to drop the block, exhaust, oil lines, etc
andy198712
interesting, i just fitted an early type beetle seal to my beetle and its bettwe then the late ones, in terms of custom use, but the foam seems better again!
Looking great!!
Looking great!!
The bay bus "H" seals are a t4 swaps best friend.
They can cover a multitude of sins.
I have tried making similar with a stripe of glue down the middle of some large neoprene foam pipe insulation, sliced down each side, but it never came out quite right.
- sweetlokin66
The foam seal allows a ton of flexibility as well as the simplicity of not needing a accommodate a channel to hold the rubber split seal. Also helps with the "factory" look I'm ultimately going for.
Close to having this half of the breast plate sealed off, have another side piece to fab and weld on and pop rivet everything together. Sheet metal screws are temp
. Only cold air allowed
- turbobaja
Oh, sweet! That makes way more sense. My eyes were playing tricks on me
. Neat how your shroud covers the cylinders and all in one smooth piece rather than the multi-piece skirts of a T-1 shroud...no pesky exhaust pipes in the way...cheater
DON'T QUIT
DON'T QUIT
- sweetlokin66
- sweetlokin66
McMaster has been my best friend. They have a ton of rubber sealing options available. I may have even found a bulb seal that may work out for the doors. Gunna buy a test piece and see if it works. I'm just trying to wrap up this engine tin ATM.Piledriver wrote:The bay bus "H" seals are a t4 swaps best friend.
- ToRy 70
Is that the airbox on your apron? Looks great!
- sweetlokin66
Yeah
The only way to fit the size filter I needed and be able to keep it on the clean air side was to run this kind of a setup. Worked out really well. Super easy to take the apron and filter on and off in one sweep.
- sweetlokin66
- sweetlokin66
- sweetlokin66
GARRICK.CLARK
Looking good.
Just something to watch for, On my type 4 turbo (blow through) I had a large intercooler like yours. What I experienced was that the boost/air speed would drop off as it entered the big volume cooler, The turbo had to work harder to put the PSI into the heads. Removed the cooler and the lag was considerably reduced.
Good luck.
Good luck.
