936 a reBUILD thread
BAJA-IT
Re: 936 a reBUILD thread
Post by BAJA-IT »
Rear tires are back on, the carb is rejetted, and the oil is topped up.
Fired it up last knight and she sounds great.
See you in Vernal next week.
BRAT Motorsports #936
560
Post by 560 »
OK, just found this thread tonight. Not sure how I missed it way back when, but I have not been on much lately sorry to say. Super great progress, info and stories talking about the car and races.
Mike
Jackpot motorsports
BAJA-IT
Post by BAJA-IT »
Wow, it's been awhile since I posted in this thread.
Had to miss the last BOR race in Jackpot back in July, we were there to help put on the race just not racing, because we found what we think was the cause of our ring & pinion troubles.
We think the side cover was cracked for some time and flexing when a load was put on it thus taking out the ring & pinion.
dustymojave
Post by dustymojave »
Now THAT'S an interesting one! I can't say I've ever broken that in a heavy duty side plate. I've seen it broken like that in a stock cast mag side plate though.
Lake LA, Mojave Desert, SoCal
Retired Fabricator
BAJA-IT
Post by BAJA-IT »
No one that I have talked to has ever seen this, I guess there is always a first.
I think it has been cracked for some time and finally broke all the way around this last time.
We also replaced the case because it had a crack from one of the side cover studs heading to one of the pinion bearing retainer studs.
Now I just need to get it back in the car for the next race Sept. 10th in Vernal, Ut.
sideshow
Post by sideshow »
So what caused that sidecover failure? too much wheel travel? Internal damage? External force?
BAJA-IT
Post by BAJA-IT »
The trans had a broken reverse gear at one time and it ended up taking out the ring and pinion, I think, but not sure, that when the tooth of the reverse gear got caught in the R&P it may have cracked the side cover. The cover was never checked because no one had seen one break before.
BAJA-IT
Post by BAJA-IT »
The trans is back in the car and the axles and tubes are on, still need to bolt them to the spring plates. We also replaced the lower heims in the shocks as they were loose.
CentralWAbaja
Post by CentralWAbaja »
When is the next race guys? Doing Vernal?
BAJA-IT
Post by BAJA-IT »
The car will be racing in Vernal, but I will have to miss this race, I will be flying back from Atlanta the day of the race. The boys will be racing without me.
kyle_pc_75
Post by kyle_pc_75 »
You gotta mention why....
CentralWAbaja
The boys will be racing without you? WOW! passing of the torch?
Very cool! Tell them that I expect a FULL RACE REPORT haha
CentralWAbaja wrote: Fri May 05, 2017 5:10 pm The boys will be racing without you? WOW! passing of the torch?
Maybe the tranny will last now :shock: :P
TimS
Post by TimS »
kyle_pc_75 wrote: Fri May 05, 2017 5:08 pm You gotta mention why....
Indeed. Curious now...
BAJA-IT
Post by BAJA-IT »
Ok then, I have to go to Atlanta for work. I am one of the top 36 Jaguar parts countermen in the country (ranked 2) and I am invited to the Guild challenge to compete with the other 35. The top 8 then get invited to go to Vienna Austria in Sept. for a week all expenses paid.
I will be back in the car for Jackpot in July.
