Project CFC#1, turbo, back halfed and light (new name, new car page 15)
66brm
Re: Project CFC#1, turbo, back halfed and light (new name, new car page 15)
The suspension is at full droop at the moment, I would drop the chassis on the ground and see where the wheels sit in the fenders before adding material. I'm assuming that the "front hood line" is sitting where it should?
bug66
66brm; here the front is pretty much mocket up right, and you can see how much it lacks in length
Boost was created only to make people smile, and make power!
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
66brm
Yeah that's more than I could see from the other pic, time to get itchy
bug66
Got the Strange brakes fitted and wanted to see the stance
Wondering about raising the rear fenders and going to 28’’ tall and 2’’ wider tires
bug66
Anyone have any good pictures of raised fenders?
bug66
Wanted a sturdy and simple way of fitting the clutch slave cylinder
- buguy
That thing is so awesome. I didn't notice all the weld work on the intakes before. Are those Speedshop TB's?
bug66
Yes. Shortened about 1”
- buguy
Nice. I assume you just did that for packaging?
bug66
Yes, and they unnecessarily long. And if I go with different heads, they are better suited for a NA engine with high RPMs
bug66
Paint 3D to the rescue
Here is the fender raised about 5-6cm
- rubenski
Looks good to me!
- buguy
Looks good to me too!
bug66
Chop chop
11cm of travel from 0° camber to the axles hit the side plates. Does not rub the arches.
This is with 26” tires. Will go 28”
bug66
I don’t want to finish the wheel arch on the driver side before I’ve tested with the bigger tires, so I started on the front again.
Made a quick bracket that will support the water and fuel tank from beneath.
Water is 25liters / 6 gallons, and fuel will be ~10 litres / 2,5 gallons. The fuel tank will be a lot smaller and welded directly to the water tank.
