Here We Go: DD Build
Re: Here We Go: Desert Dynamics Build ( Desert Dynamics Sucks )
Power bearing packers have been around for a long time but the ones I worked with used air powered grease guns, usually the ones where you have a 55 gallon drum style of greasing setup. They do do a good and quick job for sure! Good find if it works.
- dustymojave
I've had a Lisle bearing packer for decades. But it looks a lot different from that.
Lake LA, Mojave Desert, SoCal
Retired Fabricator
Retired Fabricator
DeMinimis
This took 1.5 beers for one tab (.200"). We're gonna need a bigger keg.
- dustymojave
So ya'll're gonna have sheet metal caliper brackets? I suppose you probably add like 1/4" material to the backside of that. What a PITA, huh?
Retired Fabricator
Retired Fabricator
DeMinimis
Major pita. Yes, I have .25" caliper brackets going outboard.
DeMinimis
Another beer+ down.
I wish I could weld like that!
(so jealous!)
DeMinimis
Me too.
That is still so superior to what I can consistently do.
DeMinimis
Thanks, but too much heat. Need more beers (less shakey)
DeMinimis
Wasn't cool with only six threads of engagement. 1/2" worth of Inserts doubled that.
- jg210302
Deminimis or any of you guys for that matter if you ever need to machine something small like that I know a guy with an entire machine shop! If you are local to Huntington Beach hit me up, more than happy to help...
DeMinimis
Right. Had to make spacers as caliper too close to hub otherwise. No longer perfectly centered on the rotor, but that doesn't matter as the pads self-center.
Oooooooo Ahhhh! Lookin' good.
DeMinimis
Thanks Lee. That was a stupid amount of work just so I could use CNC brakes with these spindles. Just realized, I will have to do the same with my spares. Grrrrr.
