Project CFC#1, turbo, back halfed and light (new name, new car page 15)
- buguy
Re: Project CFC#1, turbo, back halfed and light (new name, new car page 15)
That's actually a pretty good idea Lee. I had never even considered that.
bug66
I held the last pipe up with two stands and held the bend up tp the collector. Then used a protractor to see what angle I was missing.
If I where to build a lot of exhausts, I would get a vertical bandsaw, and a piecut angle kit.
Boost was created only to make people smile, and make power!
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
bug66
All four primaries tacked from collector to port flange
- rubenski
Great work!
- buguy
Dr you going to final weld it off of the engine?
bug66
Yes, the collector is double slip, so I’ll weld the runners individually
bug66
On the dolly
It slides straight out of the gearbox like this
bug66
Needed some extra quarts of oil, and no money for dry sump now
- buguy
That's awesome. Never even considered making my own!
bug66
Thanks!
Was a 3.5 quart Berg sump. Should be ~7 or 7.5 quarts now.
Will add a couple of 5/8’’ aluminium rods through it for strength, because I cut out the casted supports.
bug66
Sump all welded up and clocks in at 5.9 litres or 6.25 quarts. I don't think it was 3.5 quarts to begin with
I poured water in it and let it sit for 30 min or so, not a drop spilled
I'll do one extra brace to the block for a bit more piece in mind.
As for the longer pickup.. The extension I have now seems to be soldered on. I want to TIG the new extension on, but guess the solder will melt. Maybe I should just remove the exstension I have, and build a new one?
- buguy
That's a good feeling! Man I didn't notice it before, but that intake going into your plenums is huge! Is that 3"?
bug66
Plenums are 4’’, tubes from IC is 3’’ yes
- buguy
Damn! Expecting 700 hp?!
bug66
It's the same tube size as last setup
But need a new turbo for 700whp
