Project CFC#1, turbo, back halfed and light (new name, new car page 15)
buguy
Re: Project CFC#1, turbo, back halfed and light (new name, new car page 15)
Post by buguy »
Oooh! That's going to leave a dent in your wallet!
bug66
Post by bug66 »
Not too much news I’m afraid..
But. Header done, new turbo mounted, IC done (ish)
Body under modification and to be installed soon :)
The autumn is hunting for me, so weekends at the cabin hunting grouse :D
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
Wally
Post by Wally »
Nice how the turbo directly into the intercooler blows!
I say: good progress still. Small steps also make one big one hey ;-)
bug66
Post by bug66 »
Added some more aluminium to the bend, but thinking of chopping it off and welding a 3” bend there for less restrictive inlet
Not the best picture...
rubenski
Post by rubenski »
Optimal placement for the wastegate!
We're doin' it right ImageImageImageImage
bug66
Post by bug66 »
The new turbo is a Borg Warner S257SXE.
Should be good for this engine.
Lookin' good but, not trying to be nasty here, if you have both tires go flat or one a big bump is the exhaust system high enough to not get damaged?
bug66
Post by bug66 »
Ol'fogasaurus wrote: Sun Oct 11, 2020 1:40 pm Lookin' good but, not trying to be nasty here, if you have both tires go flat or one a big bump is the exhaust system high enough to not get damaged?
Don't know. The sump is lower, and it'll see minimum action outside the track. If a tire pops at 120mph, I've got more problems than the exhaust scratching the surface :mrgreen:
bug66 wrote: Sun Oct 11, 2020 11:42 pm
That's probably true! You build looks pretty good, it was just that one picture that got me curious.
bug66
Post by bug66 »
Ol'fogasaurus wrote: Mon Oct 12, 2020 8:12 am
I’ll take a ground clearance picture tomorrow.
It’s not that bad actually:)
bug66 wrote: Mon Oct 12, 2020 9:36 am
I am sure you are correct clearance wise. I just brought it up as a "just-in-case" so all bases are covered. Always keep friend in mind so nothing bad happens.
bug66
Post by bug66 »
Ol'fogasaurus wrote: Mon Oct 12, 2020 10:39 am
Thanks!
Thinking of it, the car will probably sit on the rear valance if the tire blows..
Low as almost can be!
Being a bit silly here but in the late 50's or early 60's when low riders were the thing ,before it became high riders due to drag racing, the low riders rule was a pack of cigarettes laid flat on the ground should just barely be slid under the frame. That didn't last long due to some bad accidents which is why the "rim rule" or 5" came in effect. That is: if the tire was flat nothing could extend below it and cause sparks or cause loss of control.
bug66
Post by bug66 »
bug66
Post by bug66 »
