My cuts into the tube were accurate enough that I only needed to make two templates. A little fiddling with the shape (and some more to do later) and they fit pretty good. On the other side, I marked the legs A and B and the jig also has A & B marked so I know how it fit in there. I new nave to put the jig back on the other frame head I had as I didn't mark the two holes on each side. The holes will be used for the support to the beam. One of the reasons I did not make the cross-piece like the kits do this time is the four holes in the front cross-piece. On the other buggy, I duplicated the holes on the top and bottom of the front piece. When I tightened up on the bolts, the strap used collapsed and I had to replace it. This time I will leave the end open and only bolt though the bottom of the leg. One bolt will be custom because of the pedal assembly which is very close to the hole. I will leave the end of the cross-piece open until the body lift is bolted in place for the final time they put a thin piece of metal over the end and tack it in place. Once the holes/slots a drilled, I can cut the bottom to length both inside and outside and then cut the inside of the tube going up the side for the slip-over fit
Once I get the holes cut, then I can start matching the cut out that was made for the pedal assembly mount. The mount will sit slightly above the body lift front corss-piece so it will have to be covered and the body flange will have to be trimmed and re1formed. Fun and games! I did lay the ;oft cross-piece against the body and the fit is close enough. I would like to have it fit better but with the pan gasket in place, it should be OK.
