Just made a truly sad discovery today! the z-bar bolts to the body, no way I can put it on my fiberglass buggy! I was in love with that design too. and strange bulges under my body make it very likly that even if I made mounts I would have clearence issues.
due to the massive weight bias in a fiberglass buggy, the biggest things I am fighting is jacking and understeer, so a HD front sway bar and a camber compensator that is NOT anchored in the middle would be the best thing for a street toy the way I see it. obviously a shimmed Z bar would be better, but no such luck.
The Camber Compensator
- fusername
Re: The Camber Compensator
JWP
I've been debating and reading through things here on this thread and the others related to suspension.
Are there pitfalls to running both a shimmed factory z bar and a compensator such as the Empi (strap style) or the Sway Away Style?
Is there a such a thing as store bought Z bar that is more capable? I say store bought but can one buy the parts for a reasonable price and swap out the bars like you can with a splined sway bars. I do realize what I've described is basically a splined sway bar with opposing arms, but what size bar would you get? Hollow or solid? What length arms, of course adjustable arms would let you vary the rate.
Not sure if this link has been posted yet. I found it helpful.
http://www.eviltwinmotorsports.com/wp/w ... 2011.9.pdf
Steve
My Baja Build
My Baja Build
- petew
BTW, I did this with my empi CC...
bumpstop + U-bolt = works like a charm
