Jps1145's Little Baja - Build Thread
- CopperBaja
- jps1145
Not much progress lately really. Just still kinda prepping it for the race.CopperBaja wrote:bump'd
I did cut the lower stops off the torsion housing and added some limit straps to the rear.
I managed to pull one of my screw-in wheel studs out of one of my drums. I had a feeling I would so I got some press-in studs in the 14mm x 1.5 variety and some matching ball seat lug nuts to go with them. (should have done it that way to begin with...
- bajaherbie
Hedrock wrote:I kinda wondered about them screw - in's. Is it a bad idea to tack them in from the inside?
what do you have?
my rear drums were studded when i bought 'em, but last year i did the fronts when i got the btr's. my ghia has screw-ins because it has 8 spoke empi wheels....
- jps1145
I've started tearing things down now the race has come and gone.
I pulled out an etirely intact torsion bar from the rear passenger side. This can only mean one thing... stripped splines in the torsion housing. Since the other side is still holding weight, I can only assume the passenger side is stripped
Looks like I will be installing an adjustable center section. Any help from experienced guys with this procedure, please chime in.
The front is also pretty tore up as well. Just about every joint broke or is cracked. I thought my spindles were bent beause the camber went from negative before the race to positive after. Turns out the whole beam twisted in the frame as it was being pushed upward. Instead of leaning back, it is now leaning a little forward... Lot's of work to do up here.
Here is what is left of the outer springplate bushing. I'm guessing this has a lot to do with the splines stripping. The outside of the torsion bar was moving around quite a bit.
Bent the tab holding the bottom part of my rear cage.
Front bolts holding my skid plate sheared
- CopperBaja
- bajaherbie
- rickosuave1987
my 2 cents....Go coil over...jps1145 wrote: Any help from experienced guys with this procedure, please chime in.
But man, that is a lot of damage! Did herbie navigate you off a cliff or something?
Do you think with more bracing the front end would have held up better?
Baja
HookIt
SuaveRacing FaceBook
HookIt
- bajaherbie
- jps1145
Maybe some day will consider coil over, but that would take a bunch more bracing in the car.rickosuave1987 wrote:my 2 cents....Go coil over...jps1145 wrote: Any help from experienced guys with this procedure, please chime in.![]()
As far as the front, there's no question more bracing would have helped along with better material for sure.
Because I kept the support for the beam inside the footwell I had little leverage holding the front. When I rebuild it I will run support Higher through the dash (I didn't want to hack the dash before, but I need to now). Plus, I will run the lower beam support back to the "A" hoop rather then just the front firewall body support. I'll be adding a bunch more "X" bracing also.
Time for a one-piece front end. Anyone have one for sale???
- seabeebuggy
Tell me you did not put the red ring over the outer flange... It did go in the torsion tube behind the spring plate right.
Just asking it looks like the photo it was around the end plate.
www.BigMikesGuns.com oe https://www.BMGAA.com
Thomas Jefferson said It may be necessary for a country to have a revolution every 200 years to right the wrongs of a Government.
Got Lead?
Got Lead?
- jps1145
- jps1145
- Lotrat
I would think that the paint would have cracked off it it did twist that much, but it looks odd.jps1145 wrote:I thought the same thing. But I think it would have twisted completely off because I cycled the suspension a few times.Lotrat wrote:did the end of the torsion bar twist?
I'll take the other one out and compare them. If they don't match, I stick the stock ones back in and see what happens.
