I'm actually finally stuffing a T4 in the 73 Square, I almost went with the 2L I have DS prepped, but couldn't "see" a satisfactory place to put the DS tank. (plus I wanted to use the factory oil cooler setup/Vanagon housing)fastback wrote:intresting reading ,as i have had the similar problem on one of my wbx engines.
fresh bearings,
i have 4,5- 5 bar at cold engine @ idle
when oiltemp reaches around 60 celsius the pressure seems to fall at more rapid rate and at hot engine/oil around 80-90 ceslius the oilpressure is only ~0.5 bar pr 1000rpm.and i have tried different oils, sanded the pump,swapped bypassvalve. and double checked readings with mechanical gauge.also tried differnet oilfilters
i uses the stock watercooled oilcooler
please post what u find out about the accusump and what hardware is needed, regarding valves etc. as im considering this soulution against the CB drysump setup (have started modified the pump)
thx
Current plan is either using a low mileage stock T4 pump or a 28mm Melling I dual oringed and pressure balanced.
If you have any tank location ideas, I'm still working on it...
