100 Cubic Inches of Fury!
andy198712
Re: 100 Cubic Inches of Fury!
yeah some learning curve! can make some big boost at low stress levels for the turbos, the way i look at it is a turbo compresses via ratios. so if its a 2:1 for eg, feed in atmospheric and you get 1 bar over atmosphere, but ram 1 bar over atmosphere in there and its pumping out 4bar....
will need some stout boost control!!
is this the first compound turbo bug???
- Chip Birks
This isn't the first compound setup in a bug. Wally did it years ago on his 1200 challenge setup. The engine didn't last long, had a bearing failure or something like that and the project got shelved. I have a friend that has a dragster with a very similar setup. He has a bypass valve between the turbos in case the big unit starts moving too much air. It hasn't run down the track yet.
- buguy
Do you have A hp goal in mind?
- Chip Birks
I'd like 350whp+, not sure I'll get it, but I'll sure try!
- buguy
Holy crap! I guess if your gonna shoot... You may as well shoot for the stars!
- petew
Looking forward to some crazy vids and sad V8 owners.
- John S.
Love it! Can't wait to see drag vids. I always thought using a short cut through the shroud was a space saving method. Glad to see it being done.
- Chip Birks
I figure that the fuel and ignition systems can support it, the turbo system should easily support it. I can cool hot pressurized air in 2 different ways, and the bottom end should be pretty stout too. Why not put it to work and see what comes from it.
I don't know that I'll keep the through the shroud intake on version 2.0. It looks cool, and packages nice, but it sure makes working on things a chore. I've had it this was for 6 years now, i think its about time for some reconfiguring.
- John S.
Maybe V bands instead of flanges on both sides of the shroud.
- Chip Birks
I have a silicone coupler on the back side. The 4 bolts into the shroud work fine enough. Just tight to work behind the shroud.
- kangaboy
Gonna be a no deck lid build then?
- Chip Birks
No decklid, no apron. Figured the draw through guys would appreciate it
I'll redo all of the plumbing later, I intend to hide it all.
- rubenski
- Wally
Re: Project "done" now what...
Cool! I build that with the 1200cc if you remember. Pity I could not get results from it.Chip Birks wrote: ↑Sun May 06, 2018 1:21 pm Compound, yes. Everything I've seen shows big turbo feeding the small one.
Space is the major isuue usually
- Chip Birks
I remember your old setup. I actually mentioned it a few posts before this one. I hope it gives good results. Not a big deal either way, its pretty easy to swap back to the big single or even the little subie setup if i need to. It'll be a fun test either way.Wally wrote: ↑Mon May 14, 2018 6:11 amCool! I build that with the 1200cc if you remember. Pity I could not get results from it.Chip Birks wrote: ↑Sun May 06, 2018 1:21 pm Compound, yes. Everything I've seen shows big turbo feeding the small one.
