This is the rear bar bolted up in the factory location. I was messing around trying to work out where to fit the trailer plug on the rear bar. I am aware that there is currently one in the engine hatch but there is no wiring to it and I don't want it there, I also think that the tyre carrier might get in the way of plugging the cable in.
I though maybe I could fit in in between the box and the rear of the body. But with it in place that gap to the back of the vehicle looks horrible. The bar is stood off a mile. It doesn't look so bad in the pictures, but in the flesh it looks like the bumper is falling of the back of the bus. Way too much gap.
Even with the box pushed in to where I plan to run it has more gap than I thought it would. The next picture the box is gapped to the back of the bus and the bumper is pushed as far over it as possible. But hoping that the tyre carrier will mask some of this gap.
I cut out the mounting plates that will be welded to the ends of the box section. I have also cut some 40mm angle that will be bolted to the underside of the chassis too. Will get some more pictures of this tomorrow.
When I cut the plates out I drilled some 10 or 12mm holes at the inside of the radius of any corners. I didn't want to cut squarely into the corners with the thin cutting disc and create a stress area that cracks could start at. Has to be strong enough to snatch 4WDs out when they get stuck, so don't want it snapping of the back of the bus!
I dropped the 100mm box off to get sandblasted inside and out. I am planning to use the box as an air tank so I wanted it clean inside. Prior to welding it up I will spray some oil in it for the time being to stop it rusting up. Then later I can add fittings and pressure relief etc.
Next up I started work on the cold air intake for the engine. I bought some tube and bends off eBay. And was trying to work out the best way to mount them to the side of the engine bay.
I was around helping someone with a few things on their bus and noticed that it had factory mounts for an intake pipe. Because my bus is injected it had the airbox mount but not these two intake brackets. So I went and had a look in the back of one of the Bay wrecks that I have and sure enough, it has the mounts. Cut them out with a cordless grinder and they happen to be the perfect size for the 2.5 inch tubing. And the hose clamps I have fit nicely into the back of them.
Started mocking up where I wan the intake to run. I wanted it a bit higher in the bay than this to get it up clean of the battery and out of the way.
I ended up cutting one side of the 45° bend as short as possible. This brings the bend closer to the intake where it clamps on and further away from the side wall of the engine bay. So it angles up for longer and tucks up higher out of the way.
I cut one leg off the alloy tubing to shorten it up to hug around the corner of the firewall above the battery. The piece I cut off happened to be the perfect length to put between the 45° and 90° blue bends. This is the intake pipe all assembled how it goes in the car.
I fitted the intake mounts using nutserts. I figured bolting them it was easier than trying to weld in the engine bay. And they are super easy to take in and out now too. The first one is basically where the factory had it. And the one above the battery I moved further out to the right of the car to support the end of the tube as much as possible.
I clamped the intake in place before getting a picture of the second mount. It is under that hose clamp there.
Intake all fitted in place.
Looking down the hatch in the back.
Heaps of clearance above the battery.
And that's how you fit a cold air intake to you bus
Thanks for looking, more soon.
Smiley
