looking forward to seeing your progress...the CHTs look VERY promising!
Happy Holidays!
BJ
trust me...i understand "time poor" for sure! keep plugging away!! my car has been sitting for 10 years. i've been working on it that long! soon though..soon...wreck wrote: ↑Fri Dec 22, 2017 12:43 am Hi BJ
I may produce a few kits but it won't be for a while ,maybe later part of next year. I'm really time poor at the moment and am making plugs and moulds for a single airbox filter system plus setting up a Megajolt ignition, fitting AC and a serpentine belt system .
I've been driving the car daily and am happy with how cool the temps run , #1 runs the hottest at an average of 120C ,#2 is the coolest at 105C .(the thermocouple is bonded to the plug boss so the readings are slightly lower than under the plug ). #1 stub pipe has a larger dent in it to clear the pushrod tubes . I wonder if it is causing the higher CHT . I'll straighten out the pipe(to match #4) early next year when I get the whole system ceramic coated .
Also the 48 Dells have a hole in the butterfly and I'm finding the idle mixture screws are very vague but adjusting them make a big difference to the CHT .so I'm going to block up the holes and see what that does .
For oil cooling I've 2 coolers either side of the gearbox with properly shrouded fans with a Mocal sandwich thermostat . the oil temps rises up to 90C then the fans kit in and regulate the temp straight back at an average 80C or so . All this in humid 30C ambient temps .
I wonder how many big bore/stroke high comp type 1's run that cool. I'll try and get a video up in the next week or so of the gauges/temps etc .
Something like that would be fairly easy to make flat patterns for then be bent up (probably stamped) in "Tin" but it would be in at least two pieces; a top and bottom. Then you have to consider just how much time there would be a lot of time spent developing the flow patterns in the windtunnel
