Things weren't that simple unfortunately...
The auxiliary vents were definitely installed upsidedown, but I still can't tune cylinder number 1.
Here is a video I just took :
https://youtu.be/5CgcMF03FpI
I was just watching the old videos I posted and it seems to me that it's doing exactly the same thing.
If I have a problem with the gap of the tappets, would that cause the issue with cylinder number 1?
The things I really don't think could be causing the issue, and why:
Leads - I have tested them, but I'm now using another set
Distributor - issue was there when the Magnaspark setup was being used, and now I'm back to the 009
Timing - set at 32 degrees full advance
Fuel pump - I'm currently using the third electric pump
Fuel filter - has been replaced twice
Fuel lines - no problems from the tank to the fuel pump, I got soaked once when I changed the pump. The line from the pump to the engine has been cleaned using compressed air
I have set the float many times
As you can see in the video, it appears to be running rich, which is cylinder number one, but I can't get it any leaner. But I didn't have that issue before, yet the engine seems to be running exactly the same way.
I don't remember ever trying a different ignition coil, so that will probably be the next thing I'll try. I'll also check the valves tomorrow morning and pull the spark plugs. But I'm not sure how any of this will relate to the issue regarding cylinder number one.
I feel I'm very quickly running out of options, and with me currently out of work, that doesn't leave much money for a mechanic. I feel the issue must be right in front of me, but I just can't see it...
Sent from my Pixel XL using Tapatalk
