Not building boost
rubenski
Re: Not building boost
Post by rubenski »
Booky
Post by Booky »
Thank you for every ones input. I am going to look at my lines .
panel
Post by panel »
Booky wrote: Fri Sep 20, 2019 6:37 am So the only thing that the turbo vacuum boost line should feed is the waste gate? My port below the carb will feed blow off valve, the fuel pressure regulator , the distributor and boost gage?
Is your Boost gauge a boost gauge or a vacuum/boost gauge ? If it's just boost you could go above the throttle plates. If it's a combo gauge you'll need to go below the throttle plates.
Booky
Post by Booky »
It’s a combo gage
panel
Post by panel »
Ah cool , keep us up to date with your progress and pics etc? What kind of car ? Looks like a rail/buggy ?
buguy
Post by buguy »
Panel what are your thoughts on where to plumb his fuel pressure regulator? Before or after the throttle blades?
Booky
Post by Booky »
It’s a Pa street legal sand rail single seat. I have the fuel pressure regulator plumed off my intake port along with distributor and boost gage.
Booky
Post by Booky »
Here is some pictures of my sand rail it’s called Black Snake.
Booky
Post by Booky »
Not sure how last picture got there.
buguy
Post by buguy »
That's awesome! Last pic is cool too!
panel
Post by panel »
buguy wrote: Fri Sep 20, 2019 11:04 am Panel what are your thoughts on where to plumb his fuel pressure regulator? Before or after the throttle blades?
Mine on my bus now (Subaru) is plumbed below/after the throttle plates. I think that's normal. When I was draw through I had a Holley Red or blue FP and boost referenced FPR also I believe under the throttle plates (boost/vacuum sourced). If you look at the Aeromotive website it looks like the plumb them into a boost/vacuum source after the throttle plates.
buguy
Post by buguy »
That's how mine is too but I've read that plumbing them after the blades will show vacuum on the regulator and actually pull it down lower than what FI requires. Carbs of course are a different story.
Booky
Post by Booky »
I had the boost reference for the fuel pressure regulator after the the throttle plate and the fuel pressure gauge was all over the place because of the vacuum. I just now remembered that.
panel
Post by panel »
If it's carbed I'm pretty sure you have to use a one way check valve.
panel
Post by panel »
.......Also what kind of FPR ?
