What's the most boost used
richie,uk
Re: What's the most boost used
Post by richie,uk »
bug66 wrote: Wed Oct 28, 2020 12:47 am
Do you question the dyno, or mock the driver? :mrgreen:
I am not sure, but has to be one of them as everyone knows 67s are fast so not the car :lol:
But one thing I always found odd is why mph is so low on your car for the hp, yes anyone can make a bad pass and ET suffers but mph normally is still near correct
bug66
Post by bug66 »
richie,uk wrote: Wed Oct 28, 2020 11:10 am
Agreed.
With 215/65 MH DOTs, 1,04 4th and 3.88 RP, it should do more than 217-219kph.
We think it might lacked some air flow to the turbo (VW Speedshop header, and filter on the turbo). Some vacuum happening?
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
Wally
Post by Wally »
Maybe the dyno number was already calculated as engine hp?
Shame there wasn't a boost pressure running on the dyno sheet, as that would tell the tale (out of steam or not) a bit better still.
bug66
Post by bug66 »
Wally wrote: Tue Nov 03, 2020 11:20 pm Maybe the dyno number was already calculated as engine hp?
It showed wheel hp (well torque and then a hp conversion based on torque and rpm). We tried a bit higher boost on the WG solenoid, but no gains.
Wally
Post by Wally »
It showed wheel hp
You're absolutely sure thats how it was read/measured, as the dyno sheet alone doesn't say one or the other. But if it is, I'll take your word for it of course!
bug66 wrote: Wed Nov 04, 2020 3:25 am We tried a bit higher boost on the WG solenoid, but no gains.
That info alone doesn't mean that the turbo is done :wink: (boost pressure vs RPM does give more info to asses the turbo's 'breathing capability' imo)
carsten bb
Post by carsten bb »
A back pressure gauge would have been fun on the old turbo.
Buy the 8 bar one 😄😄
Wally
Post by Wally »
:lol: :lol:
richie,uk
Post by richie,uk »
:roll:
bug66
Post by bug66 »
richie,uk wrote: Wed Nov 04, 2020 11:50 pm
:roll:
You can’t measure hp :wink:
richie,uk
Post by richie,uk »
bug66 wrote: Thu Nov 05, 2020 12:12 am
:roll:
If you think that then why claim how much hp it has?
bug66
Post by bug66 »
richie,uk wrote: Thu Nov 05, 2020 12:23 pm
:roll:
As you of course know, hp is just a calculated number from watts. The rollers or hub dyno measures the torque, and hp is converted/calculated from the torque the engine makes.
But we can of course disagree on the output of my last engine configuration, I know the dyno owner sat the correction factor for the flywheel conversion to 1.00.
And the first pull I did (on the same dyno as the 501/667 run) matched the numbers by a few percent when Trond had the car on a hub dyno. Same engine and transmission.
