The orifice I referred to is in the air pressure path in the gun, it doesn't handle the media, so it will last indefinitely. The ceramic nozzle at the end does handle the media, is cheap, and available from Sears, and should last 10 hours or so of continuous use.
No pitting, but I did notice a slightly rougher finish than wire brushing, and it left the metal kinda gray vice shiny. I followed the blasting up with a quick pass with the wire wheel, and it looks great now.
I swept the media up and sucked it up in my (clean inside) shop vac, and dumped the shop vac bin into the blaster's hopper twice during the evening. The blaster's got a sieve on top, and I didn't have any trouble with old paint, dirt, etc. clogging it up. A sheet of poly dropcloth, or a plastic tarp would have made the job easier.
I started with 50# of grit, and ended up with 25#. Guess where the other 25# went?
Of course, there was media EVERYWHERE, up in the fenders, on top of the engine hanger bar, etc., so I took today off and cleaned the car and garage up, wire brushed one last time, went over the engine bay with 320 grit paper, cleaned, cleaned, and CLEANED AGAIN, then applied ultra black RTV sealant on the seams. Now THAT was a nightmare, getting it to spead out and lay flat. It looks nasty, but the seams are sealed and I won't have to worry about water getting in the engine bay now.
I masked off the holes in the engine bay, and shot the first coat of (rattle-can) Self-Etching primer over the places that didn't have RTV (gotta wait 24 hours for it to finish outgassing before painting over it), and I'm waiting until tomorrow to finish priming. After a day for the primer to harden a bit, I'll sand the primer (I have a run or two in the primer
