and IT RUN'S 11's and GET'S 26-28 MGH
can't beat that
I do log my accel enrich. That pedal press wasn’t enough to trigger it and I went way lean. How do you set up the lambda delay? I really have no idea how to do itClonebug wrote: ↑Thu Aug 12, 2021 2:07 pm It could easily be your lambda delay is not set up correctly.Log your accel enrichment and see if you are actually getting any extra fuel there. That is a pretty small tps change and your fuel table should be able to give enough fuel for that.
That is why it's important to have the lambda delay close....so the correct bins get changed when it needs more fuel.
Most small throttle changes should be table adjusted so you are not dumping a bunch of fuel in for every throttle movement and causing rich spikes instead of lean spikes. It's a fine line on when to use accel or let the fuel table take care of it.
Think you could help me? I can pay for your timeClonebug wrote: ↑Thu Aug 12, 2021 5:39 pm Lambda delay is setup by watching events on your logs.
You can also set up an event or two by setting certain table areas rich to be able to log the event.
You can also watch the log and check for events that have a delay from tps or VE to AFR.....
You then left click and drag to highlight the area from say a tps movement to AFR change....or VE event to AFR reaction.
When you click and then drag to the end of the event you can see the time frame at the bottom of the screen. It will give you milliseconds or thousands of a second and you can input that into your lambda delay points.
Check the rpm and map area that it happened and input a new number......if you happen to see another event you can set the rpm and/or map line and change that too.
alright ill send over the project file and 90% of my logs are just dated so itll be east to tell which ones are recent. I also havnt run auto tune in about a month so the recent logs should be ok.Clonebug wrote: ↑Fri Aug 13, 2021 10:40 pm Send me your project folder and a few logs from a fairly long drive and I'll see what I can do.
Actually the project folder will have all your logs in it so I can check them......just make sure it isn't too big to send over email.
artledboer@comcast.net
You might have to compress it into a zip file. Just make sure there isn't a whole bunch of logs. The latest two or three should be enough.
Either that or make a new log without Autotune running. That way I can see what it actually is running like and not the Autotune chasing itself.
