Yeah I love it.
But my pushloc hose on the outlet to my pump blew off and dumped a load of oil.
That’s why I’m doing those two in ptfe now
Think it was too close to the heat of the turbo which is does say not to do in the instructions to be fair
Yeah I love it.
yeah i really didn't tighten it much either.... put a new filter on now, this one has a HEX on the bottom for un doing it which will be handy if required, its a MANN filter.
Yeah i saw yours and had a look on ebaybuguy wrote: ↑Sun May 03, 2020 5:01 am It is kind of a bummer running all the stuff for the intercooler. Once it's done though, it will work great and you won't have to even think about it again. When I built mine, I used a bilge pump for a boat and then mounted it inside the tank. It is 100% silent and I love that. Every now and then I have to open up the tank to make sure it's still working.
Thanks i'll look into it
cool, and you just have MS giving a signal to a relay to run that pump on? got a cooler in it? seems alot don't actually use a cooler as its not needed alot of the time?buguy wrote: ↑Sun May 03, 2020 9:26 am I think the tank probably is lower than the cooler. I've only had to fill it twice (I leave it all connected when I take the engine apart/out now). What I do is fill the tank, then turn the pump on via TS, then top it off and put the lid on before I shut it off. Really though it doesn't matter much because the cooler doesn't hold enough to push water back. Even if it did, it's a 1200 gallon per hour pump. As soon as it turns on it would push water back to it. Every time I have ever looked there is water in the lines back at the cooler even when it's off. Also its never had water come out when I've opened the lid when the car is off.
I have mine set to come on at 1200 rpm and intake temps above 95 degrees. It draws a lot of current so I don't like it on at idle.
