New guy, new build
buguy
Re: New guy, new build
Post by buguy »
Well I'm out of ideas brother!
Schweg
Post by Schweg »
I’m also at 120 or so ambient on the baja and with a huge Intercooler, though with water meth I never saw more then a 10° rise over ambient even at 20+ psi.
panel
Post by panel »
chriswillrise......remind us of your motor combo and anything else related to it.
chriswillrise
Post by chriswillrise »
panel wrote: Sun Aug 29, 2021 8:56 am chriswillrise......remind us of your motor combo and anything else related to it.
2110cc 8:1cr lowbugget lb2 cam 1.25 rockers. China t3/t4 from Aj sims, ms2 v3 efi
Snow performance meth pump, tank and nozzle. Can’t really think of anything else that relatable
buguy
Post by buguy »
China turbo is pretty vague. Any more specifics?
chriswillrise
buguy wrote: Sun Aug 29, 2021 9:33 am China turbo is pretty vague. Any more specifics?
buguy
Post by buguy »
Ok that shouldn't be too small to be just creating heat.
chriswillrise
buguy wrote: Sun Aug 29, 2021 9:54 am Ok that shouldn't be too small to be just creating heat.
Yeah I don’t think so either. My intake temps are right on track for not having an intercooler so I’m not worried about that. The cruising temps are just a result of everything heating up and staying hot while cruising. This is just the life of being forced induction with no intercooler 🤷🏼‍♂️ I’d love to run one but I don’t fabricate at all and I don’t want to change everything around so I’ll just deal with it
buguy
Post by buguy »
I guess. Just seems like with that thing hanging out in the breeze it should be running a bit cooler. Mine is all jammed up under the hot engine and exhaust pipes with no where for the heat to go. But it is what it is, seems like you have exhausted all your options. As long as your not getting detonation it should be ok.
chriswillrise
buguy wrote: Sun Aug 29, 2021 11:23 am I guess. Just seems like with that thing hanging out in the breeze it should be running a bit cooler. Mine is all jammed up under the hot engine and exhaust pipes with no where for the heat to go. But it is what it is, seems like you have exhausted all your options. As long as your not getting detonation it should be ok.
Yeah the air just heats up as it goes through the intake. The compressor side of the turbo is way too hot to touch just from cruising so the air heats up just passing through
buguy
Post by buguy »
Another month or so and we should be able to enjoy some lower intake temps!
madmike
Post by madmike »
Can you post a Photo of Motor ?
chriswillrise
madmike wrote: Sun Aug 29, 2021 3:54 pm Can you post a Photo of Motor ?
I did a couple posts up
chriswillrise
madmike
Post by madmike »
I would change the intake to a 'T' style instead of the 'Y' that will help with fuel atomization :wink: I had a guy making them out of aluminum tubing 2" down tube and 1 /34 " to the end castings, but It's been two years since he's made any :roll:
Motor looks good,, Luv the 'Dump Pipes'
