New guy, new build
chriswillrise
Re: New guy, new build
Post by chriswillrise »
madmike wrote: Mon Aug 30, 2021 4:23 am I would change the intake to a 'T' style instead of the 'Y' that will help with fuel atomization :wink: I had a guy making them out of aluminum tubing 2" down tube and 1 /34 " to the end castings, but It's been two years since he's made any :roll:
Motor looks good,, Luv the 'Dump Pipes'
I have a guy locally that could make me one so I can try it out. I’m going to give him a call
panel
Post by panel »
There is no fuel going through that 'Y'. How will that help with atomizing the fuel ?
rubenski
Post by rubenski »
panel wrote:There is no fuel going through that 'Y'. How will that help with atomizing the fuel ?
chriswillrise
panel wrote: Mon Aug 30, 2021 10:48 am There is no fuel going through that 'Y'. How will that help with atomizing the fuel ?
There is water meth going through the intake
Chip Birks
Post by Chip Birks »
He is spraying methanol though. Thinking it's not feeding each cylinder consistently. It's a stretch, but at this point it's cheaper than replacing the turbo in this battle for cooler charge temps.
rubenski
Post by rubenski »
Oh, makes sense then!
panel
Post by panel »
I thought Mike was saying fuel , as in gasoline. :roll:
madmike
Post by madmike »
:lol: I was , thinking it's like mine ,, :lol: sorry :oops:
chriswillrise
madmike wrote: Tue Aug 31, 2021 4:04 am :lol: I was , thinking it's like mine ,, :lol: sorry :oops:
Well 6 months ago I was like you 😂 new to the efi club
rubenski
Post by rubenski »
It's a good club to be in!
chriswillrise
Just an update but I got my water meth working MUCH better! this is a 3rd/4th gear pull in 75 degree ambient and it was about 90 going into the motor. The W/M is working so well the temps actually started to come down!
and this is an old log
Clonebug
Post by Clonebug »
Yeah...that's much better.......You are running a little rich on boost though.
I'd shoot for about 12.0:1 maybe 11.5 at the richest and see what your power feels like. 10.78:1 is really too rich and it might run better if you lean it out a bit.
Just go slow and see if you feel any difference.
125*F. IAT's aren't too bad at 14 lbs. but there is room for improvement if you tweak your system a bit. Just remember that the more hp your engine makes the more W/M you will need to add.
That is why I run a staged 2 nozzle system.
chriswillrise
Clonebug wrote: Mon Oct 18, 2021 9:56 pm Yeah...that's much better.......You are running a little rich on boost though.
yeah ive been leaning it out more. It was pig rich because of the added meth that was spraying for im slowly leaning out the fuel table
Clonebug
Post by Clonebug »
So what was the problem with the water system??????
chriswillrise
Clonebug wrote: Tue Oct 19, 2021 5:18 am So what was the problem with the water system??????
it was a relay or ground issue. I tried testing it and it would only turn on for 2 seconds then it would just buzz and stop working. Which is weird because I tested it for 1 minute strait right when i finishing up my car to test the flow of my nozzle but it mustve stopped working right after that because ive never had temps this cool
