...finally making some progress. I think.
My friend August welded up a set of CB Performance EFI end-castings for me. This guy has bailed me out of a few jams (since I've yet to learn how to weld) and is arguably the nicest guy I've met in the hobby. It was his first attempt at welding manifolds; I'm quite pleased how they turned out:
Everything from here on out is my handiwork...if it looks shoddy, call me out. This is my first try at manifold/cylinder head porting and chamber work. I've got an assortment of cartridge rolls, mandrels, and flap-wheels (60 to 180 grit). However, I wish I had a rotary file with a longer mandrel, and a longer mandrel for my flap wheels; this limits how far I can get into the port or manifold before the chuck of the die-grinder is blocking my view (and rubbing on the aluminum).
One manifold match-ported for the oval ports on my DRD L6's:
The inlet to the manifold is opened up and the wall between the ports has been pushed back and tapered. FWIW, the inner walls are not as lumpy as they appear (they are quite smooth, I must say). My smudgy finger marks and the "grain" left over from variable passes of the flap wheel give the appearance of lump/flat spots.
Exhaust valve guides have been cut down. The hump between the valve seats (opposite to the spark plug) has been removed, and the walls around the seats have been pulled back near the floor and made steeper. Overall, the quench area remains nearly the same (I pulled the wall around the exhaust valve slightly towards the cylinder). I picked up 3cc's in volume. Not much, but every little bit helps. The heads have since been bead-blasted and returned from the shop with a fresh valve-job. (sorry the picture quality isn't better...and carbon deposits are obscuring some of the contours around the seats, etc...oh well).
