Ignition only table?
supaninja
Re: Ignotion only table?
Post by supaninja »
Keep updating us Andy, this has been a very informative experiment :shock:
viewtopic.php?f=14&t=140387
andy198712
Post by andy198712 »
indeed it has!
i think part of my running hot issues was using the tinare with holes in it for the heater pipes.... since blocking those it has helped alot..... i'm going to check the plugs today and see where i'm at.
problem i had with the leaner jet was when cold started, it would start ok, but where i live i have to pull away up a hill and it wouldnt let me change into second at mid rpm, would splutter alot if i did, its now fine being richer.... and reving high enough to make the change wasnt appealing on a cold engine.
this is due to me not using the choke, which i think helps my mpg no end! using the ignition map to hold the idle.
would also help to tune the carb i guess.... just dont have an o2 sensor (yet)so its poking in the dark i guess!
tempting to fiddle the map a bit more, not sure wether to get more advance in sooner or just try and increase all but WOT by a couple degrees maybe and see if i gain or loose anything....
andy198712
Well I had a bit of a tweek on the map, and tried my old favourite carb the 30 pict 1 but it would rev out, only had about 3/4 revs when flooring it, I didn't play with it long, tried the 112 and 120 jet and didn't change much so switched back to my 30 pict 3 which I'd cleaned out the adjustment screws ect.... Put them back in the same position but it didn't run the same..... At which point I'm wonder why I bothered to change the carb lol
Bit more fiddling and it holding idle cold again now....
Really need an O2 sensor!!
andy198712
filled up again...
36.16 mpg, and that was with changing carbs about and loosing about 2-3 bowl fulls of petrol. quite pleased with that, especially when fuel is about £1.40 a litre!
supaninja
Post by supaninja »
andy198712 wrote:filled up again...
That is amazing :shock: , I wonder what fuel injection will yield?
It might do worse. Seriously.
Esp. if he has single port heads and has to use the sequential+siamese code and big injectors to get around the siamese ports.
(I have no idea how a 1200 cc late model Euro T1 is setup)
If he has working manifold heat, he probably has excellent fuel/air mixing going on.
He just lacks fine AFR control.
From a pure economy standpoint, the closes equivalent would be a TBi setup on the factory carb heated manifold, perhaps even installing a venturi or such and pre-mixing the fuel entering the TB.
(or even sticking an injector aiming down from the air cleaner at a carb w/plugged jets)
Then you could play silly buggers with the AFR/timing to see how deep the rabbit hole really goes.
More CR and a good (small) tuned exhaust would probably go a LONG way.
I pushed >50 MPG on a "custom" (emergency duct tape throw together on a weekend after swallowing a valve through an aluminum keeper) 800cc twin with a PICT 28 w/matching vacuum only advance dist back in high school.
It would do 56mph on a flat surface at WOT, but I did not have to ride the bus to school.
andy198712
if i didnt have so much money in my 2110 i'd FI my 1200, be great to see!
andy198712
if i did it, i would definitely use a twinport 1300 head (euro models), that way i could bolt on any of the EFI manifolds :)
maybe use a destroked counter weighted crank as the 1200 crank is weaker, light valve train, straight cuts (purely for low friction) and a cam that matched the combo.....
i do think with EFI i could break into the 40's easily...... but breaking the 50's would be some challenge and achievment!
i've got most of the parts to build a 1200 barring a case in the garage....
13window
Post by 13window »
stop playing with the big motor and build up a 1200 with fi be good to see the out come.
I thinking of doing the same to caths bug but with a turbo to help get up the hills around here :lol: :lol:
Did you make it over to the jambo on sat??? I had to much work on :( :(
sam
andy198712
13window wrote:stop playing with the big motor and build up a 1200 with fi be good to see the out come.
sam
:mrgreen:
i wouldnt hear the end of it, already got engine bits all over the house :lol:
wally got 150bhp from his TP1200 T i think? lol
yeah, got soaked and wasnt amazing.... i think today would have been the better day to go!
andy198712
my current map
panel
Post by panel »
panel wrote:You could also put your 110KPA up in the top (12th) row. Maybe better resolution ?
Still haven't done that yet eh :lol: (Or 100KPA)
andy198712
i'm getting there though 8) from 80 up i've gone up in 5's instead of tens but will go further ;)
andy198712
new map
tried more max advance but from 45 to 55 in top gear these seemed to be about 7 seconds down from 9 ish in the old map. no pinging i could hear... is this safe? i dont normally do full throttle tbh
cheers
ps, hows that panel? ;)
What happens when you hit a cell over 100 Kpa with the map stopping at 100? Does it just continue with the highest known value?
I'm naturally aspirated, and hit well over 105 Kpa during low 90 Kpa barometric conditions. At sea level I would be touching into 115 Kpa cells.
