Turbo this baja discusion
buguy
Re: Turbo this baja discusion
Post by buguy »
That's awesome. It was meant to be!
madmike
Post by madmike »
That CB dizzy you speak of ? does this pull timing on boost? I maybe interested in this :wink: :lol:
terryly
Post by terryly »
Hi Mike yes it does. You give a vacum/boost signal it knows the engine load by the RPM and MAP values plug it to your computer staet with a generic timing map ten you decide at what boost pressure/rpm you want to start pulling timing and you get to tell it how much to pull and how fast/slow to change it :D
Image ImageImage I orderd it for IDFs so I got those 4 little plates for single carb just need to tap the manifold after throttle plates.Very nice product and worked great ended my timing wowes Now I new what timing is at each rpm window then just tell it what to do.
Once you sample the control/ease of tuning you will probably lust for fuel injection & timing control Which will relegate this bad boy back to the parts shelf. Its its own worst enemy. After it gives you a teaser
Cheers Buddy
Terry
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
terryly
Post by terryly »
Go to CBs site and check it out . There back box does the same thing
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
madmike
Post by madmike »
as soon as you said :
"Plug it into your computer" you lost me :roll:
I don't own a laptop or,,,, a cell phone :lol: :lol: :lol: so ur selling it with the carbs? or seperate?
terryly
Post by terryly »
Well then that makes it harder :D you gotta take distributor to computer :lol:
Mike It was just a harebrained idea to free up some cash I was kinda hopping to sell it all together for ease Maybe I will post it on the STF off road for sale If there is no action locally.
Have a good one Mike
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
petew
Post by petew »
What are carbs? And what is dis... strib... oota? :P
buguy
Post by buguy »
Ahhhaaa! If you weren't so far away id send you a carb to examine!
terryly
Post by terryly »
Aint gonna be no carbs in my house if i have anything to say about it. This is my GMC I had to fuel inject it to :lol: :lol: Did it couple years ago runs good Throttle body set up from Howell AHH I long for summer
ImageImage]][/img]
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
buguy
Post by buguy »
That thing is awesome! And its front wheel drive?!!
terryly
Post by terryly »
Ya Its fun I put a Dakata digital dash in it that has a pulse generator for your speedo lets you see your zero to sixty times and quarter mile times two tipsy rednecks and myself were doing quarter mile passes :lol: :lol: 18 -20 sec depending if we were gaining elevation on the country road or losing it full of camping gear water Ahhh much fun. The old fellow I bought it off had the 455 done up with a mild cam decent heads and stout botom end. I re geared it from 307 to 373 I think I did that when I was pulling horses around. I liked that dash so much I put one in the buggy tooImage
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Chip Birks
Post by Chip Birks »
My dad has a 23 footer. Birchaven is the trim I think. I'd love to put a Fitech on it someday. It definitely doesn't have power like yours does though, thats insane! His has the old original 455, bone stock.
terryly
Post by terryly »
I have heard of guys turbo charging them My go to vendor has a twin turbocharged 455 :lol: I don,t see it in my future although I do enjoy pulling out and putting a 1/2 million dollar diesel pusher in my tail lights pulling up a mountain pass with a horse trailer in tow :lol: :lol: probably how I busted up the stock trans and a built one from a guy who builds them. I phoned him up told the tranny calfed pulling a hill coming out of the badlands of Drumheller Admitted I did some burnouts told him of a problem I was having with it puking fluid out the dipstick seemingly randomly [not really working it and I pay attn to tranny temps and have an audible warning if they approach 300* I think] He said it shouldn't have come appart he's done worse arranged to ship me a new "Mannys tranny" split the trucking/shipping costs new transmission is great no issues and runs cool. I was so impressed that a couple years later I picked up his " One ton conversion kit" that does away with the week "beefed up" Toronado pass car front hubs and bearings and replaces it with the hubs, bearings, brakes,CVs and axles from a late model GMC 1 ton truck Way stronger don't need special jig/puller to service rebuild and it fixed the GMCs narrowed front track width. Smart guys over there at GMC net USING building modifying and maintaining them http://www.gmcers.org/
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
madmike
Post by madmike »
Man them bring back some memories :lol:
I've rebuilt a few of the 425 turbohydromatic's 'finger pinchin chains in them' :roll: yepper need a huge A$$ trans cooler too'
Yes folks it's CHAIN drive :lol: :lol: :lol:
terryly
Post by terryly »
" The 26 foot 12,000 pound hot rod with plumbing"
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
