Big boost turbo's
buguy
Re: Big boost turbo's
Post by buguy »
Oh I get it man. But I can't even explain how nice it is. In fact I'm a little embarrassed to say I don't know crap about it because it really works so well I haven't had to mess with much.
GARRICK.CLARK1
Post by GARRICK.CLARK1 »
Well. I'm on the verge of giving up with carbs lol. Even the S.U wont play anymore. Think I'LL do a comp test 1st just verify all 4 are ok.
I'm gunna start an Injection thread for newbies, There's just so many different varieties though , hard to no were to start, I could do with something that will bolt on to the dell manifolds, that would save a lot of time.
buguy
Post by buguy »
Bummer. But really it will save you time and headaches in the long run. If you don't go crazy with features, an you can do a little fab work, the switch won't be too bad.
When I did mine I didn't know crap about efi, or wiring at all really. These guys here walked me through everything. Couldn't have done it without the help of the STF.
Schweg
Post by Schweg »
EFI seems intimidating at first but grasping the basics goes a long way. And depending on what you get there are built in aids to help along the way.
Also like Buguy said there are a bunch of people on here willing to help with the conversion.
buguy
Post by buguy »
What I did was break it into sections. I did the hard pieces first. Made a header and intake etc...
Then worked on wiring. Once that was done I moved on into tuning. It was getting too jumbled for me having it all roll around in my head all at once.
madmike
Post by madmike »
to bad your not state side of the pond, 4 barrel Holleys are a cheap and work great :wink:
GARRICK.CLARK1
I could get 1 over here , al bet there's some on e bay.
buguy
Post by buguy »
I think I have 7 of them. But they are still carbs my friend. Harder to get under a deck lid.
Maybe you could get microsquirt/megasquirt, some efi intakes, and use your carbs as throttle bodies?
GARRICK.CLARK1
Well , I have it running down the street, Its hunting/bucking at low throttle/low rev cruising and will only clear if I change down a gear to keep revs up. I guess my intake is too big, Its 2" from carb to dell manifolds.
GARRICK.CLARK1
So, i have found some throttle bodies with injector bosses to fit dell manifolds.
Schweg
Post by Schweg »
The EFI fun begins!
GARRICK.CLARK1
I hope its not a load of hassle like carbs are
buguy
Post by buguy »
It wasn't for me. Your gonna love it! I have a single TB so it won't be quite as easy, but way easier than guessing with carbs.
Schweg
Post by Schweg »
There is a learning curve in that it’s something new but... at least for mega squirt it’s pretty simple and self tuning helps take out a lot of what could be guess work
Clonebug
Post by Clonebug »
You will never have to smell gas on your hands again.......as the saying goes.......carb guys will think about going EFI but a Fuel Injection guy will never want to go back to carbs............I'm on my third FI setup........ :lol: :lol: :lol:
