944 NA Rear Brakes
Hulken
Re: 944 NA Rear Brakes
Post by Hulken »
I been looking through old binders and I found the pictures. What Wally used was 944 bakplates with handbrake, turned down (to 117mm outside diameter) type 4 stub axles, custom aluminum adapter plate between stub axle and rotor witch was a 944 Turbo 298x24 with 71mm height. Calipers was as I recall from C2.
I’m going almost same direction but I am using 944 NA rotors 289x20 / 71mm height - and Boxster calipers. I will take pictures and upload as I’m going ahead.
Wally
Post by Wally »
Uploaded the rear disk set-up for you guys again.
It was described pretty well in the post before :wink:
Hulken
Post by Hulken »
Nice to see the picture again!
Very nice! Thank you Wally! Not far off I will post pictures of my set up as it comes along.
Ray
