I've always had flex fuel sensors in use. Don't even have e85 locally anymore, yet I still pop them into the fuel system, just in case. This is the one I've got in my bug, and for my bus.chriswillrise wrote: ↑Thu May 01, 2025 8:34 pm As I get closer to putting in the motor I’m starting to think about stuff I’d love to do that I never had a chance to try with it before. Are there any good write ups on people using the flex fuel sensor with the megasquirt ecu in a VW application.
I assume I’d just need the sensor, get ethenol rated fuel line and some bigger injectors.
https://a.co/d/2dHqtrB
You'll need adaptor fittings to whatever you have in your fuel system. I have the sensor plumbed into the return line sitting on the pan, under my tank, just before it returns into the tank. It works great. You'll need some kind of bracket to hold it down. There are solutions if you search. I think a lot are 3d printed. I honestly have no idea what I did on the bug, it's been in the car for at least 10 years now. I still need to find something for the bus.
Wiring is easy, most modern ecus have a dedicated flex input. Just use that, I think the sensor gets 12v, signal, and ground. You'll need to buy the special connector as well. It should show up as suggested when looking at the sensor on Amazon.
I run Teflon lined stainless steel braided hose everywhere in my fuel system. Basically good for any fuel. A good set of 1000cc injectors should do you just fine, with lots of headroom for horsepower. I'm running the same ID1000s I got 13 years ago for my boosted e85 burning 2276, on my stock, yet injected, 1600 burning cheapo 85 octane, today.
