New guy, new build
Alexander_Monday
Re: New guy, new build
Post by Alexander_Monday »
Batch fire is randomly timed.
I have done batch fire both ways and couldn't tell any difference.
It is important to use 1&3 / 2&4 with semi sequential since it is timed with paired injectors firing twice per 720 crank degrees.
chriswillrise
Post by chriswillrise »
Well I got it running again. I pulled the ms2 apart and realized i ran the second ignition driver to a different spare port so I just had to switch that.
Still only running on 3 cylinders because my #3 injector is stuck but the new ID1050x injectors come friday
Last edited by chriswillrise on Wed May 21, 2025 10:31 am, edited 1 time in total.
Chip Birks
Post by Chip Birks »
Awesome news!
chriswillrise
Just seeing if there are any other settings I need to mess with with the new id1050x injectors other that required fuel
Alexander_Monday
Dead times and voltage offsets.
Chip Birks
Alexander_Monday wrote: Fri May 23, 2025 1:20 pm Dead times and voltage offsets.
Hopefully that data is available for them on the website, I believe they had the data for my ID1000s when I needed it.
Alexander_Monday
It is.
To fill out injector deadtimes table you have use the spreadsheet and enter the different fuel pressures you want in the table.
chriswillrise
Test drive happening either today or tomorrow!
V8Nate
Post by V8Nate »
Hell yeah that's awesome!
Alexander_Monday
Great to hear!
I detect model aircraft.
When I was a kid I did u-line and graduated to remote control aircraft.
Been several decades since I have flown.
chriswillrise
Alexander_Monday wrote: Fri Jun 06, 2025 1:03 pm Great to hear!
Yeah that’s my second expensive hobby. I’ve been flying for a couple years now
I used to race RC cars, off road or 10/12 scale carpet 3x a week, depending on season.
Crack would have been far cheaper and less addictive.
chriswillrise
Would anyone be willing to take a look at a log and my tune just to double check everything is set up correctly? VE table is off still as I havnt gotten much tuning time. I havnt even gotten into boost yet.
VE table is close enough to drive decently from a couple cruises with auto tune on
chriswillrise
Well Ive been cruising! Slowly worked up to spring pressure at about 9 lbs. Put a couple hundred miles on it so far and everything seems to be holding up
panel
Post by panel »
Draw through eh ? Looks so cool ! Weird seeing the TB at the intake side of the turbo.
