If I change the pin from A7 to A0 or A1, the baro reads correctly, and boost/vac gauge in TS also works... But engine runs like garbage. Set it back to A7, engine runs fine. Did you still need to see the .ini file? Is it the "maincontroller.ini" file?
Changed acceleration enrichment from TPS based to MAP based. Seems to work much better. Although I am just revving it to test.
The Aufgeladen Ghia
- Alexander_Monday
Re: The Aufgeladen Ghia
Your VE table is tuned with Baro being wrong and Baro is part of the fueling equation.
I assume you have either used auto tune or manually adjusted it to make it run right and with correct Baro the table is off.
That is my guess anyway.
No need to see the ini, it is probably just fine.
- xzener
Yes. I use autotune. My observation is the VE table is tuned per RPM and manifold pressure... If baro is wrong (which we all see it is), how does autotune make the adjustments? You would think the wak baro reading would, in turn, make a wak air/fuel adjustment. Am I reading too much into this?
Boost is contagious.
- Alexander_Monday
Baro is part of the internal equation for pulse width.
PW = REQ_FUEL * VE * MAP * E + accel + Injector_open_time
E = gamma_Enrich = (Warmup/100) * (O2_Closed Loop/100) * (AirCorr/100) * (BaroCorr/100)
Bruce.m
Yes, the autotune will target the required lambda reading, and correct whatever cell in the fuel table that reading relates to. So if the Map is 100kpa but the sensor is reading 70, it will just feed whatever fuel the engine needs and stick it in the cell for 70kpa. If you fix a problem with a sensor used for the fuel calc, the table will need fixing to match.
- xzener
Right... But what am I to fix, or is this an issue that needs fixing?
- Alexander_Monday
I suppose as long as Baro always gives the same reading I would think you could leave your tune set to that.
But if Baro is a floating pin there is not any guarantee that it won't fluctuate under some conditions so I would want to fix it and redo my tune.
Or at very minimum set "Baro Sensor kPa At 0.0 Volts(kpa)" and "Baro Sensor kPa At 5.0 Volts(kpa)" both equal to the reading you have been getting (around 214) so you will be sure it will not fluctuate, but of course your TS boost gauge and possibly others will not give accurate readings.
I drove around for ages with no baro sensor, on MS it grabs a reference at power on from the manifold vac sensor.....
That's OK unless you have a reset while running, in that case the reference is whatever the current manifold vac is, does not work well...
...so the added a setting to set the reference to a range.
Mine was .99-100KPA.. don't know if speeduino does that, but if it does, it works great unless you live in the Rocky Mountains or Alps etc... Set it to whatever your MAP sensor reads before cranking.
Given that you have boost 2nd baro is likely more important, if you have the sensor, they usually work.
I picked up some tiny pcbs off Ebay with 2 SMT sensors on them (you order the components from Digikey and solder together)
I'd set them up a bit thinner, and they have a tube nipple with no barb, but I have my MS3s in MS1 cases.
(one is actually a V1.01 mainboard, one is a V2.2, neither are "supported" configurations, you are better off with a V3 board but I have never had actual reliability issues with the ECUs)
