Drag and Drive Baja
buguy
Re: Turbo/EFI Baja
Post by buguy »
How bout this and then you could put whatever you want for springs in it?
https://vwparts.aircooled.net/Dual-Valv ... rental.htm
Schweg
Re: Turbo/EFI Baja
Post by Schweg »
I would but Aircooled.net is basically shut down right now to catch up on orders so that options out. For now. I don’t mind the beehives and I may go that way and build a 90.5 x78 stroker as I can use the heads I have for some cost savings.
Chip Birks
Re: Turbo/EFI Baja
Post by Chip Birks »
Schweg wrote: Sun Aug 01, 2021 6:49 am I would but Aircooled.net is basically shut down right now to catch up on orders so that options out. For now. I don’t mind the beehives and I may go that way and build a 90.5 x78 stroker as I can use the heads I have for some cost savings.
Assuming that valve top that siezed your engine didn't destroy the chamber too. Definitely big potential for that unfortunately.
Clonebug
Re: Turbo/EFI Baja
Post by Clonebug »
Without having to research it all again...what is your cam and rocker combo???
Those look like stock pushrods and it is possible with that style end it ran out of travel and bound up at full lift in the rocker cup. That would bend the push rod and cause all kinds of pain and agony.....
Schweg
Turbo/EFI Baja
Post by Schweg »
Clonebug wrote:Without having to research it all again...what is your cam and rocker combo???
It’s a SCAT C25 cam and SCAT 1:25 rockers.
I’m hopeful its not screwed
Also the end came loose on the bolt together rocker.
Chip Birks
Re: Turbo/EFI Baja
Clonebug wrote: Sun Aug 01, 2021 11:20 am Without having to research it all again...what is your cam and rocker combo???
That pushrod was black. Stock ones are raw aluminum. Looks like one of the cheap chromoly pushrods. My bet is that a valve spring broke, valve hit piston, bent pushrod and knocked it's head off. Lucky it only happened on one.
Clonebug
Re: Turbo/EFI Baja
Post by Clonebug »
I have some cromoly pushrods and they have the different style ends which allow more angle for the rocker cup......It would pay to check the clearances.
It could be those rockers don't have the clearance for that style pushrod end.
I have three used sets of 88mm P/C's if you want any of them.....I can't say they are good but if you want a single or even the box I can get you them.
buguy
Re: Turbo/EFI Baja
Post by buguy »
Oooh! That's a good offer! Let's get him back on the road! I'm looking for a set of springs as we speak!
Clonebug
Re: Turbo/EFI Baja
Post by Clonebug »
buguy wrote: Sun Aug 01, 2021 1:19 pm Oooh! That's a good offer! Let's get him back on the road! I'm looking for a set of springs as we speak!
I would question the spring thing. I never had any sign of valve float with .526" lift with my W-100 and 1.4 rockers. You only lifting to .500 should not have an issue since your cam is pretty mild.
Even now with the CB 650 outers and .522" lift I haven't seen any sign of it....not that I've pushed it too hard.
buguy
Re: Turbo/EFI Baja
Post by buguy »
Dang it. I don't have any extra springs. Anyone have a decent set of HD singles? I will still send my head tool so he can get them swapped.
Schweg
Turbo/EFI Baja
Post by Schweg »
Buguy I appreciate you looking! I’ll buy some high rev singles no issues
Clone- unless it’s an unseeable clearance issue everything moves free and have plenty of clearance.
I may very well be taking you up on the piston offer.
As for the bent push rod I am not even more concerned cause the valve damage is on cylinder 4.
The bent pushrod came from cylinder 3. Just need to get the head off and see what I did. Maybe I’ll get it next weekend.
If all else fails I can go back to 85.5 pistons and cylinders and my old heads. At least I’ll have full flow and a new cam
buguy
Re: Turbo/EFI Baja
Post by buguy »
Oh i didn't know the push rod wasn't from the same hole.
woodsbuggy1
Re: Turbo/EFI Baja
Post by woodsbuggy1 »
Sorry for your engine damage, I plan to use beehive springs on my next engine there seems to be several advantages to them.
Please let us know what all parts you need, pretty sure that most of us have a few parts laying around that could use a new home.
Good Luck
Kenric
Schweg
Re: Turbo/EFI Baja
Post by Schweg »
I will ask once I get this thing apart. Gonna be a week or so till I get it broke down.
Chip Birks
Re: Turbo/EFI Baja
buguy wrote: Sun Aug 01, 2021 1:56 pm Oh i didn't know the push rod wasn't from the same hole.
Me either :shock:
