Well, you're here...73AZ wrote:Qurtys Lyn wrote:Sneaks and I will beat you numb with a wet noodle if we find out about bondo usage...
If you read that quickly it sounds just plain wrong.
What sort of place is this, anyway?
Devastator's upgrade
- Sneaks
Re: Devastator's upgrade
BAJA-IT
it's a Happy Place!!!
Now let's keep it that way!!!
BRAT Motorsports #936
73AZ
Touche.....Sneaks wrote:Well, you're here...73AZ wrote:Qurtys Lyn wrote:Sneaks and I will beat you numb with a wet noodle if we find out about bondo usage...
- Devastator
WOW! That's the most attention my build thread has gotten since I started it.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- Devastator
Has anyone ever heard of cutting an o-ring groove in a 930 CV joint to keep it from leaking CV grease when it gets hot?
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
Rbob
You have more followers than the "Pied Piper". Are you ready for your annual "Dunes" trip?
- Sneaks
Ok, my official vote is don't cover them. I like the raw simplicity of it.
73AZ
I have never heard of it.Devastator wrote:Has anyone ever heard of cutting an o-ring groove in a 930 CV joint to keep it from leaking CV grease when it gets hot?
Is leaking grease that big of an issue with 930s?
Devastator, if it was done, wouldn't the groove have to be ground in? I know that the outer spacer in an IRS, the one with the tapered end, had a groove in the small area that went against the outer bearing's inner race that accepted an "O-ring" but they stopped doing it. I wonder if an "O-ring" would really work that well. I am sure that the German engineers must have considered it, they are pretty through after all.
- Devastator
Hi Bob!Rbob wrote:You have more followers than the "Pied Piper". Are you ready for your annual "Dunes" trip?
I'm just happy someeone is looking at those pictures I posted and not blasting me. I'm planning on the dunes trip over the Halloween weekend...if I get my upgrade done. The rear is nearly complete, and I can run with my old school front
end if I have to.
Thanks for the vote. I am keeping score.Sneaks wrote:Ok, my official vote is don't cover them. I like the raw simplicity of it.
I see CV grease external of most 930's, from heat I assume.73AZ wrote:Is leaking grease that big of an issue with 930s?
The only area of a CV outer housing that is heat treated is the area that the balls roll in. The outside can be cut with carbide tooling. That's how some cut "cooling fins" into them.Ol'fogasaurus wrote:Devastator, if it was done, wouldn't the groove have to be ground in?
I may be wrong here, but I think that spacer is the same for a swingaxle, and that the oring was needed to keep the oil in.Ol'fogasaurus wrote:I know that the outer spacer in an IRS, the one with the tapered end, had a groove in the small area that went against the outer bearing's inner race that accepted an "O-ring" but they stopped doing it.
I don't know if them germans suspected the use we offroaders had in mind for their CV's. Now that I have a flange and CV joint in hand, I can see where it would be difficult to put an oring in that, limited, area. I'll research it some more tomorrow, when I'm at work.Ol'fogasaurus wrote:I wonder if an "O-ring" would really work that well. I am sure that the German engineers must have considered it, they are pretty through after all.
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
I thought that the outer spacer for the IRS and the spacer for the swing were of different thicknesses. The outer bearings in the two systems are different or so I thought; Oh well, so much for thinking
. Thanks for the info about the localized hardening on the CVs, I didn't know that they were like that.
- Devastator
That is probably correct, (I don't remember either). But the o-ring is still used and located in the same place as it would be on the IRS.Ol'fogasaurus wrote:I thought that the outer spacer for the IRS and the spacer for the swing were of different thicknesses. The outer bearings in the two systems are different or so I thought
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- fusername
depends on the mfr and era of the cvs. I cut the center star on my cvs to run them on my bus as my axle was too short by 1.4, and it is cheaper to cut a groove for the c clip to slip into than it is to buy new axles. on orignal VW joints you can cut very easily the center of the star, but if as you get close to the grooves you start shooting sparks and getting jitter. I did not try cutting the outer piece, but hte material and colors from the hardening process appear the same.Ol'fogasaurus wrote:I thought that the outer spacer for the IRS and the spacer for the swing were of different thicknesses. The outer bearings in the two systems are different or so I thought; Oh well, so much for thinking. Thanks for the info about the localized hardening on the CVs, I didn't know that they were like that.
however on an EMPI joint the cetner star is MUCH harder all around, and no cutter would even touch it. most likely they save money on heat treating by usieng a harder steel to start with, or use a cheaper full surface hardning processs, unike what appears to be a flame hardening process on the og joints.
I also have a second set of CVs, lobro, that I could only cut a very small groove into the star before the cutter stopped, so there was some kind of hardness going into the star there. But if you look at stock cvs you can see the discoloring around the ball 'races' where they were hardned.
- Devastator
I was only referring to the outer housing of the CV joints. I should have been clearer on that. The ball races on the outer CV joint housings are induction hardened while the rest of the housing is not. I've not messed with the inner star part of the CV's, however. I have Lobro's and am considering lightening them by removing stock from the O.D. of the outer housing, (just like the racers do). I'm also considering counter boring the inner stars, (as you did Fuser), in order to put my axles in a "happier" place, and reduce the amount that the inner star will extend into the axle boots during full droop, thus reducing the likely hood of blowing the CV joint sky high.
Oh, and there is not enough room to put an o-ring in the CV's.
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
- Devastator
My shocks arrived today!
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
