2109cc turbo build...
- rubenski
- petew
Re: 2109cc turbo build...
Have you got decklid stand offs? That would scoop cool air into the engine bay and help bring the temperature down.
btw, looks like a great little car. ☺
- Volky
Hi,
When I turn on the car in the morning it barely idles when cold. I then touched the #1 exhaust pipe and it is warm to the touch. You can even grab it. Not the others, those will burn your hand. I thought it was the spark plug, changed it and still the same.
Any thoughts?
Any thoughts?
1970 VW Beetle with 2109cc turbo with MS-II v3.0, wasted spark, electronic boost controller, dual table, launch control and 3.88 tranny. All done by me...
t03 running 48lb. Injectors, Intercooler, Water/Meth injection at 15psi.
- petew
Have you tried pulling off the plug wire when it's running and seeing if there's any change?
66brm
Also you could move that injector to see if it follows otherwise it could be wiring to the injector
...could be a tight valve...
