Side mount turbo
buguy
Re: Side mount turbo
Post by buguy »
I'll wait patiently
nbuscemi
Post by nbuscemi »
As requested... sort of. Here is a quick vid going around the block. Tune is about 75% complete. Still need to set Accel Enrichment and timing. Fueling just needs to be smoothed out but these will have to wait until I'm on the dyno.
Enjoy.
https://www.youtube.com/watch?v=mSPD7jS-Wa0
-Nick-
buguy
Post by buguy »
Sounds great man! Nice job!
I would try to tune as much as possible before adding accel enrichment though.
panel
Post by panel »
Nice job Nick !
nbuscemi
Post by nbuscemi »
buguy wrote: Sun May 24, 2020 2:11 pm Sounds great man! Nice job!
Accel is really all that's left. Idles smooth, cruises at 14-15:1, and pulls like a train at WOT. Only issue really is throttle tip in. If I snap the throttle too quickly it will hesitate for half a second.
-Nick-
buguy
Post by buguy »
Understood. Sometimes you can go in and manually add fuel to the cells that need it and that helps. But the AE is there for a reason. Gotta give it what it wants.
nbuscemi
Post by nbuscemi »
It's been a while since I posted to this thread but I finally got a few pictures of my turbo setup outside the car. You;ll notice that the Up-pipe after the collector has been upgraded from 1-5/8" pipe to a 2" pipe. This allowed the turbo to spool up a few hundred RPM sooner.
Enjoy...
-Nick-
panel
Post by panel »
And did you change the WG angle for better flow ?
nbuscemi
Post by nbuscemi »
Yes! The turbo (TD04-13L) originally had an internal waste-gate, of which I'm sure was more than enough for what I'm using it for. I welded the internal gate passage closed and added the external gate for better / easier boost control (main reason was so I can run open dump on the gate).
