Tuna can? I can imagine what you mean, the strainer moves down, then you have to extend the oil pickup tube too I guess? Bascially like those type 1 mini sump extensions you see from time to time? Then put the AN fitting in the side of the tuna can. GREAT IDEA, THANKS! I'd better have a Tuna sandwich for dinner tonight thenWally wrote: ↑Wed Aug 21, 2019 6:12 amUphill is no good of course, I used the (old BAS) elongated oil strainer ("tuna can") for return as I run dry sump as well. Its the lowest part of the engine by far. Worked very well. I did use AN12, so if you can...bigger IS better as far as oil return lines go.split1950 wrote: ↑Wed Aug 21, 2019 6:00 am I'm just ordering some fittings for my turbo and have come up on a few issues, anyone got any type 4 experience here?;
1. The -AN10 turbo oil drain I had originally planned on using was by feeding back to the oil filler block off plate, but I think the pipe will go slightly uphill. I assume this is no good as this is not gravity? I'm running dry sump so I'm wondering if I can get away with that as there is some suction in the crank case?
2. I thought about going in somehow at the oil strainer cover as I'm running dry sump the scavenge is higher volume than the oil feed, so will I get away with the turbo oil return being below the oil level (I assume dry sump isn't really dry and still has some oil in the bottom of it) helped by the increased pick up suction from the scavenge?
3. My EFR7168 has an Aluminium centre housing and ceramic ball bearings, Borg says it must be water cooled. Bugger. Using the water system from my chargecooler is dumb and going to ruin the performance of it by heating the water? I think I probably should have a separate water cooling system / radiator / pump for cooling the turbo centre housing?
What do you know?! Thanks!
Watercooling the center section is overrated imo![]()
But seriously, I run the EFR7670 version with cast iron center and same ceramic ball bearings and mine has the same 'advise' from Borg. I discarded it (I have with all other turbo's as well, inclusing Garrett's GT-3076R): all worked fine without it. In fact, floating bearing turbo's don't need it from the factory and do not even have a provision for it, like the EFR7670''s predecessor: the S200-7670 I ran before.
My thinking is that the ball bearing versions produce even less heat in the bearing section and the alu centers cool themselves (since alu) even better too. So why would they need it now?
YMMV however![]()
Lol I wondered about the water cooling too, I suppose Aluminium expands a lot more than steel when heated, but then surely the oil must cool the housing. I suspect as long as I let the engine idle before shutdown I'll be alright (Borg would of course play it safe to allow for lack of mechanical sympathy).
Thanks as always dude for your help
