im putting discs all around my bug what master should i use?
- mlski67
- bender
The MB 23mm MC was stock on all 6.9 SEL 116 chassis, Not to hard to find...I'll see if i can find a part #...I think i payed about $200.Derrick from NC wrote:Does anyone know what year/model Mercedes the 23mm mc that is a direct bolt-on for a beetle? Perhaps a part #?
Bite my shiny metal ass
'59 Twin Turbo Vert Beetle
'65 13 Window Deluxe
LuftWagens Klub Candy-ass free
Fort Lauderdale, Florida
GARRICK.CLARK
Re: im putting discs all around my bug what master should i use?
Guys, Can you help me out with a brake issue.
I did have standard discs/drums in the rear on my 67 bug.
I switched to disc front and disc rear.
I now have no brakes, pedal just goes straight to the floor and wont pump up if pressed multi pull times.
I have bled the brakes as normal. Didn't expect this to happen.
- Kafer_Mike
Did you replace the master cylinder? If you did, did you bench bleed it? I have found it more difficult to prime a 'new' master cylinder and build pressure without doing it first. If did not replace the master cylinder, it may (now) have a bad seal. The Beetle master cylinder's plungers are used to a certain amount of travel in the bore. Over time, corrosion builds up past that point. In bleeding the brakes and fully depressing the pedal to the floor, the corroded section of the bore can rub and/or rip the plungers seal, allowing fluid to pass and not allowing you to build pressure.
GARRICK.CLARK
Hi Mike. I didn't replace the M.C , only thing I did was remove the rear brakes , undue the brake pipes from the axle tube and leave the ends open for a period of 2 weeks or so while I did replaced the gearbox. So I need to look for a leak at the M Cylinder were the rod goes in.
GARRICK.CLARK
Just blanked off the rear caliper pipes. Pedal did have a bit of pressure build up at the bottom of the travel. reinstated the rear calipers and back to no pedal pressure.
SC3283
cast or stamped steel caliper brackets? im guessing stamped steel.
70, 74 beetle, 81 Chenowth, 66 Fastback, 83GTI, 85GTI, 02 GTI, 72 Std Beetle
dragvw2180
Make sure the bleeder screw is the highest point when you try to bleed it , otherwise air will stay in the caliper.
dragvw2180
