www.apfelbeck.nl
mikko k
Post by mikko k »
Wesayso wrote:
mikko k wrote:They have done a great job!! I do respect that. BUT, Why a 12 valve heads? Porsche has done 4 valves heads for years! Why don't develop a 5 valve cylinder head with twin spark and douple OHC heads?? No rockers, no mass, more revs, ect.??
4 valve aircooled heads are prone to have cooling issues at the exhaust valves. Even Porsche used water cooling on the 4 valve heads. The cylinderheads we are working on were designed long ago by a great engineer. That's the main reason we stick to this concept.
Even we have wild dreams of DOHC but hey, we're working on finishing a part of history here and we are not complaining :wink:
And I do believe we will not stop after this :shock:
Very very good!! I really don't complain, just go further!!
Wesayso
Post by Wesayso »
Hi all,
Just wanted to anounce a small update on the Apfelbeck project with some new 3D Graphics...
Wally
Post by Wally »
I really like how the central valve cover turned out. Very solid. I hope Roberto can CNC it out of an alu block very soon :lol:
Also very cool how you managed to improve the original heads(molds) design with the 'slight' modifications you incorporated into them.
It sure looks to turn out even better than Herr Apfelbeck ever would have dreamed of :wink:
Thanks Ronald!
Groeten,
Walter
Wesayso
Post by Wesayso »
Another update on the Apfelbeck Project...
Some of you might have seen the first pictures of our new Cylinders on Jake's forum, but some better Pictures are available now on www.Apfelbeck.nl
As well as a new look on the Home page ;)
Enjoy!
The Apfelbeck Team
Wesayso
Post by Wesayso »
A week ago we gave a presentation of our Apfelbeck Project at an Autodesk Inventor User Group meeting. For this event we played with the new Inventor Studio to create a new movie. Needles to say that movie can be found on our site www.apfelbeck.nl
A small preview:
Ephry73
Post by Ephry73 »
SWEET!@
E
Can Drive Soon
Post by Can Drive Soon »
What would you think the redline could be on these heads? 9,000+?
But, you do know where this is taking you, don't you?
The heads probably wouldn't be the limiter anymore.
With Pneumatic valve springs, 15K would probably be reasonable ;-)
(Why doesn't somebody make "generic" pneumatic valve springs?
Too many racing classes outlaw them?)
Can Drive Soon
15,000! Wow thats like higher thatn a Ferrari, or Lamborghini. But I think 15 might be too high. Les wait and see what the Apfelbeck guys say.
Wally
Post by Wally »
Can Drive Soon wrote:the Apfelbeck guys
Haha, that sounds funny!
Well, we won't know for sure either of course, but we have selected the valve train components for the first prototyp ( 2 liter) engine to accomodate indeed somewhere around 9000 rpm with some reserve build in iirc. But if it still is making more power at 8000 rpm and peaking at 8500, I would be very happy :D
Being able to rev 8500 rpm or making max power there are two entirely different things mind you.
Since we will be using a small stroke counterweighted crank (66 mm) and some other (semi-common) tricks in the oiling department, the rotating masses should be ok for that rpm as well...
Can Drive Soon
You sholud build and engine just to blow it up to find the absolute redline. (1 of my supid ideas). If you have money to burn.
Wesayso
Post by Wesayso »
Can Drive Soon wrote:You sholud build and engine just to blow it up to find the absolute redline. (1 of my supid ideas). If you have money to burn.
for a minute there you sounded like one of our Team members :lol:
Can Drive Soon
Want and more ideas? :lol:
BAVWCJoel
Post by BAVWCJoel »
Just outta curiousity... I was wondering how the cam/vavle train was going to recieve any oiling. Sense you moved the cam out to the heads now it is nessicary to have a decent oiling system to reach the cam bearings, and all the high friction areas. And seems like before with the pushrods, there was adaquet oiling to the heads. But sense with your motor there is going to be no use for them, and you probably welded up the original pushrod tube holes on the case itself, does this limit your heads to a 2 stage oiling system with a dry sump? Again I'm just curious as to how this is gonna work out. I can see the use of a belt drivin 2 stage dry sump. They heads are sort of like split heads, in that it's a head per a cylinder, with a porsche like cam running through 2 of them, or am I seeing this all wrong?
Thanks.
Joel
Wesayso
Post by Wesayso »
BAVWCJoel wrote:Just outta curiousity... I was wondering how the cam/vavle train was going to recieve any oiling. Sense you moved the cam out to the heads now it is nessicary to have a decent oiling system to reach the cam bearings, and all the high friction areas. And seems like before with the pushrods, there was adaquet oiling to the heads. But sense with your motor there is going to be no use for them, and you probably welded up the original pushrod tube holes on the case itself, does this limit your heads to a 2 stage oiling system with a dry sump? Again I'm just curious as to how this is gonna work out. I can see the use of a belt drivin 2 stage dry sump. They heads are sort of like split heads, in that it's a head per a cylinder, with a porsche like cam running through 2 of them, or am I seeing this all wrong?
Thanks.
Joel
The heads will recieve the oil trough the Cam. That way we can reach every bearing and other places we need oil. Oiling systems like this have been used succesfully in racing and in road going cars.
You're right about the dry sump pump an again right on the Porsche like cam trough the seperate heads. Porsche has a seperate single cam housing however joining the heads on each bank.
