Chenowth Explorer A-Arm Build
dustymojave
Re: Chenowth Explorer A-Arm... My SLOW Build
Post by dustymojave »
Yeah...that was what I was thinking...
Lake LA, Mojave Desert, SoCal
Retired Fabricator
59Bisquik wrote:Hopefully, they stand by thier products and will exchange it.
I am sure they will just don't be in a hurry. :twisted:
59Bisquik
Post by 59Bisquik »
They sent the arms to the fab shop and said they are right. So, I cut off my pivots and started over from scratch. Still no luck, way to much camber at ride hieght. Looks like I will be calling Avery's and having a custom set of arms made. :evil:
motorbreath53
Post by motorbreath53 »
WEAK. No amount of adjustment available? How about cutting off the inside bung of the upper arm and shortening a bit... that would bring your camber in... maybe ask one of the CAD suspension guys to give up some ideas?
Baja5 was right...
59Bisquik
Post by 59Bisquik »
Actually MB, its the rear arms. I even cut off the inner pivots and set them up again, with no help.
The front suspension is good to go!
Devastator
Post by Devastator »
59Bisquik wrote:Actually MB, its the rear arms.
Is there a problem with the parts I made for you?
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
motorbreath53
I was wondering what you were seeing... the pics of your front end looked fine to me.
disregaurd then...
...i'm an idiot :oops:
Baja5 was right...
59Bisquik
Post by 59Bisquik »
No problem MB... I should of been more clear
Devastator, nope, not those parts at all, they are great. Its the actual 3x5 arms that have horrible camber at ride height.
59Bisquik
Post by 59Bisquik »
Since I now have to purchase some new custom arms, why not build something like this? I built my front suspension, the rear looks about the same in difficulty level in the terms of fabrication. These were taken from a Chenowth chassis and the rear is very similar. What are the pros and cons to this type of suspension versus the typical IRS style?
TimS
Post by TimS »
Pro - maybe use non-plunging CV's. I was looking at a super sweet Artic cat wildcat the other week, it has non-plunging cv's and they flex pretty good.
BAJA-IT
Post by BAJA-IT »
ts39136 wrote:Pro - maybe use non-plunging CV's. I was looking at a super sweet Artic cat wildcat the other week, it has non-plunging cv's and they flex pretty good.
Was that a 2013 red limited you wewe looking at? :wink:
It is a nice ride with 18" of travel all the way around. :D 8) :lol:
BRAT Motorsports #936
JUSSUMGUY
Post by JUSSUMGUY »
On your existing arms with the bad camber issue is there someway that you could rework them to get rid of the problem? Tim reworked an arm that had a camber problem on his green bug. Just seems that would be easier and get you to the dirt quicker.
Devastator
Have you tried rotating the inner pivot mount around the torsion housing? That can affect camber a lot.
Sandrail
going fast enough."
Mario Andretti
59Bisquik
Post by 59Bisquik »
JUSS and Dev,
I cust off the inner pivots and installed new ones. I verified my torsion housing was level also. When installing the new pivots to try and fix this problem, to get the camber correct at ride hieght, the pivots would have to hang below the torsion housing! It would take that much movement to make them work, and then they dont want to line up on the ends of the torsion. Im not really wild about cutting the arms and trying to bend them either. I dont want to create a weak point. Anyone done that?
JUSSUMGUY
Post by JUSSUMGUY »
I went back thru your thread to look at the arms you are using. Without all the microstub stuff on have you checked what the angle of the plate at the end of the arm where the unit bearing bolts on at ride height? Since microstubs bolt on can you add a washer or some other kind of shim to help reduce the amount of camber? Is it possible that you have say two left side arms instead of a right and a left?
